I have a feeling this is going to get expensive.
Ron Sebastian
Vero Beach
Ron
Custom Deluxe V10
So far I have changed tires and had them road force balanced with weight hammered onto the rims, not the little stickers ($1100). Went through two sets of tires, so thinking they are good but the rims are suspect. Then changed all steering tie rods and ball joints ($1200). Just finished adding pinion shims to the rear, now TC and rear end is within specs, also changed out the U joints on the rear drive shaft ($150). Still have a little vibration. Next step is aluminum milled rims and putting my tires on them ($1400), then getting the driveshaft balanced and probably lengthend an 1" or so ($350). I'll get my money back when I sell it right, it's an investment!
WP29P4A
Nevada
Sierra Classic V1500
A mystery vibration?
Has anything you have done so far made any difference?
Two other things to check just to eliminate potential causes would be shocks? Hub centric VS Lug Centric wheels with correct lug nuts? Pretty sure a tire/wheel shop would have noticed Lug centric wheels with the wrong lug nuts, but it sucks when something so small is over looked until after spending a bunch of money.
Camar068
10 yrs Air Force
sorry but I can't imagine spending that much money for anything you've listed.
Matt69olds
Central Indiana
GMC 1/2 ton
455 Olds
Try flipping the driveshaft 180 degrees in the rear yoke. You could also try reclocking the converter on the flywheel.
Ron Sebastian
Vero Beach
Ron
Custom Deluxe V10
Big Chip
Michigan
Kevin
C35
Is it a cyclical vibration or constant?
Ron Sebastian
Vero Beach
Ron
Custom Deluxe V10
It starts around 35 mph up to about 55.
Ron Sebastian
Vero Beach
Ron
Custom Deluxe V10
The 4 degree pinion shims corrected the drive line angle and torqued down right. Also traction bars added for anti axle wrap fixed it.
jp wessels
