I got owned. It's not a TH400 . Diff between TH350 vs. TH375
4WDKC
Southern Florida
Kacy
I thought the 375 was BOP trans..look I learnt somfin... if the 375 is the mostly the same as the 400 like mentioned above, I would have it upgraded to the 400 and then never wonder if you are overloading it..
73c20jim
Tombstone, AZ
After all comments, I will probably use the TH350.
Thanks for the replies.
.:patriot:
:big_banana_Dance:
hatzie
k20
My first two cars were a 1973 Pontiac Catalina with a 400 Pontiac and 1973 Bonneville Wagon with a Pontiac 455. Both of them had a TH375. My grandfather towed a travel trailer all over the desert southwest for over 210,000 miles with the Catalina on the original transmission. The Catalina was my first car. I killed that transmission with just over 300,000 miles on the clock and I wasn't easy on that beast. The motor lived on in the Bonnie Wagon after I discovered why you don't rev a 455 into the stratosphere.
My 1976 Delta 88, 1976 Grand Prix, and 1975 Cutlass had TH375 transmissions too. Never had a Chevy with one but supposedly they did exist.
There were at least two TH375 transmissions.
The early TH375 is a Medium duty TH400. It has TH375 cast into the transmission body. This one is a TH400 with one less clutch in each drum and an output shaft with TH350 diameter and splines. It's a pretty stout transmission.
The TH375B is a Heavy duty TH350. This one is still pretty stout but not as stout as the earlier TH375.
If it works and it's the right bellhousing pattern I wouldn't hesitate to use it... Or you could put a 350 Rocket in your truck.
78C10BigTen
pennsylvannia
C10 BIG TEN
Well crap, now you guys are going to make dig out the book and verify if the 375 is in fact a BOP only. Tune in later. 4 am comes too darn early!!!
You aint gotta tell me! I go to bed at 7 to be up at 3
Matt69olds
Central Indiana
GMC 1/2 ton
455 Olds
Matt69olds
Central Indiana
GMC 1/2 ton
455 Olds
The 375B is a heavy duty 350 made for Buick. I figured it would have been used in any heavy duty TH350 application. Doesn’t matter, it’s easy enough to machine the direct piston for 5 clutches
Rusty Nail
Rusty
350sbc
My first car was a 1976 Delta 88 Royale. What a fantastic automobile that was! I continue to look for another one 25 years later.
73c20jim
Tombstone, AZ
Now I'm back to not being sure which is the better transmission.
Boonie
El Dorado, KS
Brent
my 74 has a t350, and it hauled hay, fuel, fencing supplies, and pulled a grain trailer for 35 years with no issues.
Carb'ed Vortec 350
What is BOP?
hatzie
k20
Some of those 70's land yachts and barges like my Bonnie Wagon are nearly extinct. Mom had a 1970 Delta 88 that retired in 1983 with over 380,000 miles. The NYS winter salt ate it up after they moved to Upstate NY.
88chevy
