I burnt it up didn't I? Take a look HEI got wet.
Nasty-LSX
TogetherforeverCovid19
HOUSON TX
Mi Hung Lo
c10/k10/k20
LSX
So as I was getting the K20 cleaned up (motor) I took it to the car wash and sprayed the engine to clean off
grime cause I have a leak between the intake and the block (FRONT AND REAR) and am changing intakes while im at it. I have done this
a million times with no issues. BUT this time the truck would not start afterward. (the wash) My brother in-law came with a super strong
leaf blower to blow the water out of the HEI. Still no start. We tow it back to my house I pull the cap and its full of water on the base side.
I get my air nozzle and blow 120Lbs of air at it and get it super dry. Then I spray brake clean on it to dry it up followed by more air.
Then I used my propane torch to make sure its dry and it still caught fire LOL. I made sure it was super dry with compressed air. When I turned the key she fired right up. revved it up a couple time and then she died. would never start again. Did I burn the module up. This is a billet distributor and I dont just want to throw it away. Got to be something simple right? Going to use the one from the 80 Z28 for now :rolleyes:
RustyPile
Elkhart, TX
Nick
1983 GMC
350 SBC
Remove the rotor check the bottom for "tracks". The high voltage may have found a "shortcut" and burned a track through some leftover moisture.. I echo what squareroot said.. Why did you take a torch to it?????
In any event, replace the module and pickup coil. Like a cat, neither of these pieces like to be wet.
No
No
No
No
No
Just an FYI those Street Fire distributors are absolutely no better than the $50 ones you can get on eBay. It's literally the same exact thing without the stickers. Just buy another one and get over it.
squaredeal91
Cave junction Oregon
Greg bush
1991 SB
5.9 Cummins 12 valve
Might get away with simply replace icm. I wouldn't throw it away if the shaft is tight. Buy quality parts you trust and Replace the module and since it's out get a new pickup coil and you'll have a "rebuilt" unit.
No
No
No
No
No
Again the Street Fire is a rebranded Chinese $50 dizzy. Why spend $40 to maybe fix it when you can spend $50 and definitely fix it? Guess it just doesn't make sense to me
squaredeal91
Greg bush
1991 SB
I understand your point as I've bought several of those 50$ distributors to replace ones with worn bushings and such and think there pretty good overall but the electronics are cheap and don't last as long is all. I've been burned by cheap electronics too many times lol.
darrel
