Hub Caps for 4x4
Questions or make offer PM me.
What about that pully in the center, would it happen to be a 4 grove and for sale as well?
Looks like a small block pulley. What was a 4-groove ever used on?
id imagine 4 groove would not be 4 equal grooves. if it even is a thing on its own (not an add on pulley over a 3 groove) id still question the sizing relative
also, if one is to drive from the water pump only, if you use an add on pulley even if it spaces oddly you could space whatever is driven to be the right spacing, just a thought
SirRobyn0
Rob
IIRC, they were only used on SBC medium duty trucks with A/C as those, or at least some of them had dual belts, two running the A/C & P/S two running the Alt. And that's just what I'd like to dual belt my alt without removing one from the A/C & P/S.
I think I have one in my pile of pulleys.
If you do let me know.
Just like I said above for application and routing, and yes they are 4 equal groves same size diameter not an addon.
Sorry Roger I missed the part where you said PM with questions. Not trying to steel your thread.
Can you purchase a pulley to meet your need? since used may not have the right offsets, belt groove sizes etc anyway
if it requires purchasing a couple pulleys in a set that isnt soo bad
He just informed me that the pulley is NOT for sale.
SirRobyn0
Rob
@AuroraGirl @AyWoSch Motors @bucket I was incorrect about the 4 grove pully being one piece. There is a broken one in the shop, and the inner 2 pullys are just regular.... Metal IDK the word I'm looking for at the moment. But then the outer 2 are cast iron. If I get a chance this afternoon I'll take detailed pictures.
steel?
Yes that was the word I was looking for lol at me...
are they shaped different? seems weird to have a mix unless the cast/steel are shaped in a way that only cast could slot in the center of steel
guillermoariast
