Howdy from Hutto! '87 R1500 6.0/4L80e
foamypirate
Central TX
Jake (Mr. Wilson)
El Camino, baby!
5.3L/4L60E
I like the look and idea of those cast manifolds. Heard way too many horror stories about cheap headers.
350runner
tx
Ceasar
This guy is innovative. So what will you brackets cost?
foamypirate
Central TX
Jake (Mr. Wilson)
El Camino, baby!
5.3L/4L60E
Maybe I can convince him to whip up some brackets for a 5.3L in my Caprice. :D
Stewzer55
Ohio
Stew
R30
The Caprice would be much mo' betta with a 5.3... Get a later model double hump cross member and use dual exhaust too.
scottybaccus
Central Texas
Scotty
GMC R1500
Thanks guys!
I'm doing the mount adapters for $75 shipped, with hardware.
350runner
tx
Ceasar
Million dollar question. What have you done for the AC compressor and hoses?
scottybaccus
Central Texas
Scotty
GMC R1500
Ah, yes. The A/C. Not quite a million dollars, but possibly as high as $500.
I'm using the truck mounting, without modification. It will use the OE belt and tensioner.
There are two compressors used on these trucks. One has a single manifold for both hoses. The other uses a split manifold arrangement, having a bolt retaining each hose. (see pics)
This is the Denso 10S20F
This is the GM HU6
In either case, custom hoses will be required. This is easiest to achieve by using a manifold adapter of some sort.
These adapters come in the form of short aluminum lines that extend from the compressor manifold by a few inches, and allow a standard A/C metric o-ring fitting to connect, or smple blocks that bolt on and accept the new hoses right at the compressor.
Companies like Nostalgic A/C Parts have all kinds of problem solvers. And then the other end of the hoses simply mate to the OE condenser and drier fittings...
Minor notching of the top frame rail edge may be needed, depending on the adapters used, but nothing structural.
The electrical side on my truck is controlled by the ECM. It takes a A/C On command from an existing wire on the old system, at the firewall or behind the dash controls, directs that to the required pin on the ECM which then commands the compressor and fans as it did in the LS application, via the various pressure sensors. Fittings for pressure switches may be needed on the new lines, depending on compressor used, etc.
My ECM runs Fan 1 on a standard strategy (on @ 200, off @ 190), and Fan 2 on command with the A/C, or in the event that coolant temps reach 220. The blower motor wiring is unchanged from stock. A/C cut-off occurs above 88% throttle.
On a side note, the OE hoses from the LS application may have these aluminum can looking reservoirs down near the compressor. These are intended to collect liquid coolant when the system is shut off, so that that coolant won't gather in the compressor ports. When this happens, the compressor can hydro-lock at start-up, causing damage. This may be immediate, or it may be a longer term issue. Even with these OE hoses, some models using low mount compressors have issues. I am still considering whether to retain that design or try another option.
This other option is a start-up timer, made by Four Seasons, called a DeSlugger. It is Four Seasons part# 36141, and it accepts the ON command from the ECM or control panel, then relays this to the compressor in pulses, cutting on, then off, and on again, in a fairly rapid manner. This allows the compressor to gradually work through the collected liquid, extending the life of the compressor. This is not an OE piece of engineering, but instead it is a development from an OE supplier of A/C components. I'll be asking around to see if it is worth the $45.
RetroC10Sport
Green Bastard Parts Unknown
Jay
pontiac aztek
What are you bringing to Top Notch on Saturday? I will probably be up there with my 1989 Sierra.
Also see you're friends with one of my favorite cars in town...BG Toro. Love her and Norma Jean.
scottybaccus
Central Texas
Scotty
GMC R1500
I'll be in my truck. Supposed to pow wow with a client about his '31 Ford. Keep an eye out for me and my hat.
:welcome: from N.E.
raylanr
Campeche, MEX
Franc
Welcome I'm also near Pflugerville
big swol
Plantation
curtis
c 10
brand new to site ..... want opinions or the best motor mounts everyone is useing for a 2004 5.3 swapped into a 1981 c-10 bagged
scottybaccus
Central Texas
Scotty
GMC R1500
Mine!
Click on the link in my signature and visit my shop page. Message me there and I'll hook you up!
Nasty-LSX
TogetherforeverCovid19
HOUSTON TX
Mi Hung Lo
c10/k10/k20
LSX
Welcome. You found a awesome forum:gathering:
kparris
