How Will My Square Body Look With XX Lift and XX Tires?
Kapdin
North Dakota
Lance
1977,1979,1984,1987,1988
Silverado K30, Scottsdale K20, Silverado C10, Silverado V10, Silverado V20
400ci, 350ci, 350ci, TBI 350ci, TBI 350ci
Here's my old daily driver - '91 V3500 w/ 6" Rough Country & 35" BFG's on 12" wide Weld's.
DAYUM! thats my tuck, 91 crew :leghump:
I like the combo. I was hoping to do a 4" suspension lift with 36" tires, but no one makes a AT tire in 36" (gota worry about ice and snow here). So i guess I'll have to get 37's, but will they rub with a 4" lift?
Yeah, they will rub. May not need to trim much at all if the rims are relatively narrow (like 8") and the tires run a little small for the size. But with a wide rim and a tire that measures close to the indicated size, plan for a lot of cutting or more lift.
nvrenuf
Mobile, Al.
I miss that truck so bad... :(
I've always been amazed that it hasn't popped up on a bulletin board but it hasn't. It was in Wyoming the last time I Carfaxed it.
big chevy
ga
mike
big chevy
18 inches of lift and 50 inche tires
Swims350
Logan WV
none
HAHA yea it's freaking awesome!!!!!!!!!!!!!!!!
big chevy
ga
mike
Thanks
I drive this truck at least 3 times a week. it drives good for it size and i have always thought these was the best body styles.. I need to go up about 4 to 6more inches to clear the tires so i can put uncut fenders on it. Just not sure how to do it???
Swims350
Logan WV
none
how high is it already? can you get higher lift springs?
can you put in add a leafs with already lifted springs?
e-z inch or zero rates would get you another inch, longer shackles might gain some, and then shackle flip front or rear if you don't already have them, body lift if you don't already have one of those.
Driver4r
Nebraska
Trevor
k10,c20
Are you running 15" springs and 3" body lift?
benjaminearle
Atlanta, GA
Ben
K10 LWB Fleetside
'97 L31 Vortec 5700
By your name I'm guessing you know this, but the Fall Guy truck was 4" lift and 37" Dick Cepeks. Not that TV is reality, but...
I, personally would like to see a 3" kit with 35x12.5-15s on 15x8.5s (due to the fact that I can get a brand new 3" Rough Country spring lift with shocks and brakes for under $400. Logically, it should work as well as a 4"/37 setup.
bfd378
texas
matt
k1500
350ci
1985 4" suspension 33x15
hirschdalechevy
norcal
rich
k-30
Here is my new 77 blazer I am in the process of putting together.
8 inch skyjacker , with 0 rates front and rear for 9 inches total
40/17-15 gateway gumbo monster mudder's on 15x14 bart wheels.
guillermoariast
