How To Refurbish Your Dashpad
Stewzer55
Ohio
Stew
R30
Can the dashpads interchange? I have seen speaker pods mounted above the dash on some 73-80 trucks.
Driver4r
Nebraska
Trevor
k10,c20
The front of a 81-87. Its shorter from top to bottom on the face side.
bigcountryguy19
Sealy texas
josh
6.2 diesel
I will be definatly trying this on my truck when I get to the interior, maybe I will paint the door panels and trim with the Bed liner too!
tomtom1954
Custar Ohio
Tom
Scotsdale
This isn't show quality, but I think it turned out great for a daily driver.
You'll probably be starting off with a dash that looks a lot like this.
First, take a sharp knife and cut off all the curled up edges along the cracks. Cut back far enough to get into the vinyl that's still somewhat soft and not dried out. Also be sure to remove the vinyl around hairline cracks as that area is already toast and will become a bigger crack later and ruin your beautiful dash.
Then cut all the perforated areas out of the 2 outer speaker locations. We'll fix those areas later.
When you're finished with all that, take it outside and wash and scrub the crap out of it with some good cleaner/degreaser. I think I used Simple Green and a bristled brush.
Then I flipped it over and glued a piece of fiberglass to the underside of where the center speaker use to be using a can of spray adhesive. If you want to keep your center speaker, well uh...too bad. :gr_grin:
Then go to your local hardware store and get a can of Gap & Crack Filler expanding foam. DO NOT buy the Big Gap Filler. It expands WAY too much.
Spread a bunch of newspapers out on your work surface. When you think you have enough, put on a couple more layers. This stuff sticks to everything. Now put on a couple pairs of latex gloves.
Take that nifty can of spray foam and very slowly and carefully fill in all the cracks and holes in your dashpad. Use just enough to barely fill in the cracks as it will expand a bit. If you get too carried away it will expand a lot and the voids will be bigger and more work to fill in.
Hopefully you'll end up with something like this. You can see where I got a little too much in several places.
Let the foam cure over night so you won't run the risk of it being gooey when you cut into it.
Take a fillet knife and carefully cut the foam down level with the dash surface. You should end up with something like this.
For this next part, I forgot to take pictures :hidesbehindsofa: but it should be easy enough to explain without them. You need to cover that foam with something to make it solid like the rest of the dash.
Go back to the hardware store and get some Plastic Weld 2-part epoxy. Read the label and make sure it will bond to vinyl. This is the stuff I got.
Mix some up and let it sit for 30 seconds or so. If you use it right away, it will be too hot and will melt the expanding foam. I suggest practicing this on some scraps of cardboard and the extra blobs of expanding foam that fell on your newspaper first so you can get the hang of how long it takes to "heat up" and then how long you have to work with it before it gets tough. I'll wait here...
Got it? Alright, now that you've got the hang of it, mix up just enough to do a couple square inches at a time. Try and do it all at once and you'll get angry in a hurry. Spread it on as thin and as smooth as you can while still filling in all the holes and completely covering the foam. You don't want any exposed foam when you're done. Let that cure overnight.
Next I used a palm sander and some 300 grit(I think) sandpaper to smooth the epoxyed areas back down level with the vinyl. If you have any low spots you can go mix up some more epoxy and fill them in.
Now that everything is all smooth, take another piece of sandpaper or a scotchbrite pad and scuff up the rest of the dash pad.
Next, go to the auto parts store and get a couple cans of spray-on bedliner. I used Dupli-Color Bed Armor.
First, wipe down the whole dash with alcohol. Then follow the directions on the can and spray the whole dashpad. Don't go too heavy with a single coat or you will get runs in it. I got carried away and got a couple small ones. Let that dry overnight.
I originally intended to stop here, but I didn't like the finish on it. So, I went back to the hardware store(again) and bought a couple cans of Krylon Fusion satin black. This stuff is great because it will bond to darn near anything. They have a large selection of colors so you might be able to find one that matches your interior. Follow the directions on the can and paint right over the bedliner. If all goes well, you'll end up with this.
But wait! What about the outer speaker holes? I must have looked at a thousand different pictures on google trying to find something to use as speaker grilles. In the end, I was going through a box of computer parts and noticed the grille on a spare fan. Aha!
There are a bunch of different styles of fan grilles out there, but I went with the basic black mesh thinking it might look factory to the unknowing observer. 120mm seemed to be the best size. I got mine from these guys:
http://www.coolerguys.com/840556087601.html
Now you just have to line them up, drill a few holes, and bolt them down with some machine screws.
Here's the finished product. You can see where I didn't take enough time to smooth out the epoxy so you can tell where a few of the cracks were. And you can also see one of the runs I got in the bedliner on the flat area above the gauges. I never thought it would turn out this good so I didn't take my time like I should have.
And finally, installed in the truck
And that's it. Feel free to experiment and let me know if you find anything that works better than the stuff I used. Thanks for reading guys!
Great job! Im gonna remember those tips. Thanks.
NOPHO84K30
north phoenix
justin
1984 silverado k30
K30 dana 60 corp14 ff
454 sm465 np205
Looks good I did similar but used flexible blck caulking then covered it with a carpet dash cover with spray adhesive then got a billit dash trim on the a/c holes .....anyone that has that trim piece knows what its good for ..wifey loves to ware dresses...
82chevy350
Van Buren, AR
Joey
C10, K10, K5
Looks great man! I cheated and just covered mine with camo fabric you buy at wally world! but I screwed up and didn't do a write up haha the guys already jumped on me about it lol.
snowpro90
Buffalo,NY
Doug
Suburban R20
Nice job man and way to bring that dash back to life again.
RetroC10Sport
Green Bastard Parts Unknown
Jay
pontiac aztek
Just don't do this......Just don't. Don't do it!
Stroked
Beloit, Kansas
Jared
^Lmao!! What would possess someone to do that?
Boone83K10
Boone, NC
Benjamin
That's a nice dash pad? The steps are the same whether you have 1 crack or 50.
This obviously won't work if half your dash is rotted away or something...
Here's mine Stroked...
Stroked
Beloit, Kansas
Jared
Ehh.....I think you have a pretty good chance of making that one look good. It'd just take a little longer.
That is pretty bad though. :Grenade:
Driver4r
Nebraska
Trevor
k10,c20
I know what mines gonna look like XD.
DavieL
Alabama
Davie
5.3 LS with Holley EFI
That is a great looking dash repair, and thanks for posting, I think I'll try it on mine in the summer.
guillermoariast
