How to flush transmission
73OLyellow
San Diego
Marcel
Help! Whats the easiest way to flush a transmission on a 73 chevy c20 350?
73OLyellow
San Diego
Marcel
Or drain.. id rather just drain the bad fluid and replace with new fluid.
[yt]MsdPAadc9fY[/yt]
MadOgre
NA
NA
NA
NA
NA
Ya that's pretty much what I posted on your other thread
350runner
tx
Ceasar
Same here...:)
73OLyellow
San Diego
Marcel
And this is the same for a 73? Thanks guys!
73OLyellow
San Diego
Marcel
Okay now I need to know where the return line is and where I can find the drain plug on a 73 c20
SAATR
Here
Travis
305 cid
No drain plug on a Th350 or Th400. Generally a good idea to drop the pan, clean or replace the filter, clean the pan, inspect what you can see, and install the pan again with a new gasket. The trans filter is little more than a screen anyway, so replacement isn't really an issue. The lower line is from the transmission and the upper is the return to the trans, if I remember correctly.
Sent from my XT912 using Tapatalk
MadOgre
NA
NA
NA
NA
NA
yep
:welcome: from N.E.
Andrew45
