Knockingdiesel, the bolt came out, but prying the intake manifold off crumbled the outboard corner of the bolt hole. Apparently prying on cast iron is a no-no... I have about a quarter inch of thread left below the bottom of the failure and it doesn't seem to have gone near the water jacket. I may just thread it in and JB Weld it.
Hey, sorry, I couldn't quite tell from the photo. That I have never run into.... The last SBC I had worked, had a heli coil in one of the intake bolt holes and exhaust bolt holes. As soon as I stuck a wrench on them I could tell there was something up with the hole. Maybe they were not installed properly or something. But if they were installed properly then I would not recommend them. Perhaps someone who's installed them will chime in
I have used many helicoils to save automatic transmissions, both in the valve body bolt holes and in the front pump bolt holes when the aluminum threads give up. Used one in an intake once where the thermostat housing bolts to the intake and the old threads had just rusted away. All with good success. Patience and being 100% sure to use the correct drill bit size is the key to a helicoil being successful or not.
In this case, I would only use the helicoil as a last resort. Reason being, this isn't a situation where the threads are gone, it's a case where the material is gone. Helicoil will need that material to help support itself. If you have 1/4in of thread left at the bottom of the bolt hole, that's what I'd concentrate on making work. If it doesn't then I'd go with the helicoil and I'd still be leaning on that 1/4in of material to support the helicoil, but I just wouldn't drill it unless I had to cuz the helicoil is a last resort 1 shot over the bow to work. If it don't work at that point, then I'd say you're fuct and probably going to have to replace the head or have someone put in some weld material and tap it, then it becomes a huge project.
To have the best luck in getting that last 1/4in to work, I think I'd clean the threads that are left by running a tap. Not to cut any threads, but just to clean the threads because I know how those holes tend to get grungy and rusty. So clean the threads by running a tap, then blow the hole out with air to get all the debris possible out of the hole. Then you're going to want to use a little longer bolt than was previously used so you can take advantage of all the threads that are left. I'd go to the hardware store, Lowe's or Home Depot and I'd get a BRASS BOLT in the specialty hardware section. The brass is much softer and not as likely to do damage to what threads are left. The brass should give up before those threads give up. This way if something does go wrong, or the bolt gets seized, the bolt will give up and you'll still have your threads left and you'd have another shot at it with another bolt. I also would not get extremely aggresive on tightening that one either. Be sure to have plenty of silicone around that water jacket and be more dependent on the other bolt on the other side of the water jacket to hold.
wow.....I see it now. Never put what your prying with in a hole like that. Good reminder to everyone to not do it. Sorry for saying but thanks for the reminder.
Hope it works for you. What did you use to pry, big screw driver or something bigger? if you didn't put a lot of pressure on it, I'd wonder about the shape of the rest of the head.
