how hard is it to rebuild a 205 - what might be needed from a shop
Daveo91Burb
Vancouver, WA
Dave
V2500 Silverado Suburban
Vortec 383, modified TBI/4L80e
Hope this isn't too much of a hijack, but I have the same question about my NP 243. the only reason I'm thinking rebuild is it's leaking and I don't think it's coming from any of the shaft seals since I've done those recently. I'm wondering if I could just split it open and reseal the halves. But if I do that maybe I should just put a rebuild kit in it?
TubeTruck
East TN
Denis
Suburban K10
LQ9
I rebuilt mine. No special tools needed, no presses, no special snap ring pliers (just a basic set). You just need a deadblow and some punches and a larger diameter bar and a screwdriver. If you're careful you can seat seals and bearings with a hammer and a plastic rod. (I'm ready for the flaming :popcorn:)
@AuroraGirl here's a good guide: http://www.wideopen4x4.com/NP205RebuildGuide.html
Nice. by deadblow do you mean brass hammer or do you mean just a 3 pound sledge kinda thing
tubeofsand beat ya to it lol. He was just tellin me about a hammer that has little trucks inside for deadblow uses
75Monza
Colville, Washington
K30, K20, K20
Lol, I tend to not read much.
sirweesarunch
Oceanside
. ... This is a great np 205 video.
sirweesarunch
Oceanside
Yes , you need a press , the small home built tool to press out bearing races . Dont just put in new bearings on old races. To do it right you need to set case crush on center idler gear with a dial indicator , a Harbor freight unit will do. Its a simple operation. Take fotos as your disassembling. No video has every answer so document your own and take notes like I did. Dont be intimidated, you can do it , go slow especially on tear down. Boil all your parts out using TSP. You mentioned the Sm465. I rebuilt that as well. Its trickier / harder than the transfer case manuevering the lower shaft out. I got tons of fotos for reference if you need it.
3dbello
