How... do you build a stepside?
Since my box is about rotted off id say by the end of the summer i was looking at options. currently, I have a long stepside box (jusst the square part) and prob fenders. but i wouldnt know yhow mounts or flooirng works. fuel fill. etc. Any insight? I could either make it for trailer or put box on truck. whicever i prefer i guess.
SDJunkMan
Black Hills of South Dakota
Jeff
Stepsides have supports going across the box that the wood flooring attaches to. The wood is held in place by metal strips and a ton of bolts. Here is a pic of mine after I took off the cross braces.
Sorry I don't have a pic of them in place, but you can see the marks in the wood where they were. There was one on each end, and a pair of them before and after the axle.
You can also see the fender braces that keep the fenders from flopping around. The fenders are bolted to the bed sides.
SDJunkMan
Jeff
So how does it mount to the frame?
SDJunkMan
Jeff
There are bolts that go thru the wood, crossbraces, and finally the top lip of the frame. Seems like there were 8 of them. You can see tabs on the rear crossmember (top of picture) and some larger holes in the wood where some of the other crossmembers went. The bolts had a carriage head and went through a large washer with an offset hole.
eskimomann209
Modesto
Marcus
Bolt lengths are different from the fleet side bed as well. I’m sure most would work but I’m told a couple were the wrong length. Got my stainless steel bolt kit off a kid with a step side. He said they didn’t work for him due to it being a stepper.
So.. you need to make sure to have a floor first before you can mount the bed? And whwre might I find those braces?
SDJunkMan
Jeff
Whattup friend? @SDJunkMan ?
I hope you and the family are well.
Hey Rusty, we're doing fine, daughter in law (lives in Denver) may have a mild case of covid, but it hasn't hit in our area yet (6 cases).
Sorry to hear that your girlfriend has the covid crap.
Waiting for the weather to break so I can get to some of my projects. Looks like we will be getting snow again this weekend.
SDJunkMan
Jeff
1980_C10_STEPSIDE
Seattle, Washington
Salvador
I was reading through this thread, great info by the way. I think I may be missing one cross brace.
Is that the standard layout even for the short-beds?
Turbo4whl
Downingtown, PA
Wayne
@GMC_Nick While looking for information for Taylor I found a post for your stepside. Does the stepside bed bolt to the frame or brackets on the frame?
What Mike said, @AuroraGirl any progress?
By the way, did you ever get the rack sides? I made a set from red oak. 1 x 6's for the sides, but I needed to rip saw the uprights to the correct size. I used 1/4" carriage bolts from the inside so no bolt end to snag the load. I recessed the nuts into the thicker uprights.
Ken B
indiana
ken
here is a pic of the bottom of my bed if that helps at all
lorisa2u
