Hood issues
Silver 79
Houston
Sergio
Having issues with the hood not closing all the way in the back. It has like a 1/2 in gap. I hear it's a common problem with this year truck. I have replaced both springs and hinges. Ideas anyone?
74 Shortbed
Just need to be adjusted, loosen the hinge and have someone lift the hood all the way up then tighten the bolts and it'll close right.
1987 GMC Jimmy
Automobile Hoarder
Mississippi
Jesse
V1500 Jimmy
Those little rubber bumpers on the core support are adjustable, too. They don't do as much, but it's worth noting.
Craig 85
Nashville, TN
454/TH-400/NP205
Lower the rear portion of the hinges. It should bring it down.
Silver 79
Houston
Sergio
Thanks for the info I will definitely try it.
There's also a tall fender bolt at the rear corner of the hood. It's supposed to slide into the inner structure of the hood when the hood closes. It's purpose is to help keep the hood from going into the windshield during a wreck, but if the hood isn't adjusted well enough, the hood just slides over the top of the bolt keeping it from lowering down. That bolt can be removed while getting the hood adjusted where you want it, then just put it back in when you're done. Or replace it with a regular fender bolt.
Misty Blue
