Homemade and modified tool thread
10.00 brake pressure bleeder. The pressure part is a 6.00 Dollar General plant sprayer. The clear tubing came from the hardware store..The pressure cap is a piece of scrap aluminum plate with a hole drilled and tapped for a barbed fitting.I glued a piece of rubber to the other side and clamp it down with strap iron, all thread and old exhaust springs.
A bearing separator, some all thread a hyraulic jack. I pull crank gears, bearing races etc. Put the jaws together and it's a little press
2 tools here. A piece of steel rod I had laying around and a piece of scrap strap is brake pedal depressor.The second is a piece of plate with a hole with a socket through it and welded.You put your breaker bar in the socket and put pressure on it smack the plate clockwise or counter clockwise with a hammer, for that really tight stuff.
78C10BigTen
pennsylvannia
C10 BIG TEN
I used something similar to pull the front pump outta my th350!
A piece of square tubing a scrap of flat plate, and a tire machine duckhead.Because the junk mount bars they send with the manual tire machines won't pull a tire on and I don't like prying them on. IT'S SOMEBODY ELSES TURN!!
A 13 piece bearing race and seal installer, that you can take off nuts and bolts too. Okay I don't really have those, or any harbor frieght sockets.but I do use my sockets for driving in seals and races I just don't have a pic of my sockets handy.
Okay, not mine. I have a press and my bearing separator press, But I like this probably will make one for ball joints and U joints. Yes I have the big c clamp service press but think this will be more useful.
Twistedwhisky
