Highbeams blinking
LDO
MS
Bob
I was driving down some dark roads the other night, no oncoming traffic so I switched my high-beams on for a bit. About 3 or 4 minutes after, on their own, my high-beams start flashing off and on, in other words, from low beam to high beams. It kept cycling like that until I cycled the column stalk myself and then it was fine. Few minutes later, same thing, they started cycling.
Anyone have this happen to them before and if so, is there a fix or something I should look at? Already looked at the electrical connection at the connector end; it was fine.
thanks.
ajd89
Central Michigan
andrew
Maybe a bad ground wire connection ?
Switch adjustment?
Snips71
