skysurfer
- Oct 23, 2010
- west coast
- John
- 1989 Suburban
- V2500
- 5.7/TH400/NP241C
Spent a few days working with the Harbor Freight sandblaster and thought I'd review it since rust is a common issue.
http://www.harborfreight.com/110-lb-pressurized-abrasive-blaster-95014.html
I bought the largest model (95014) they have because it comes with a deadman's handle to control media flow. The smaller ones come with a simple ball valve and they didn't get good reviews.
So here's what I got...
Sale price was $139.99 and I used a 20% coupon so I got it for around $110.00 plus tax.
They carry a few types of blast media at HF but it's cheaper to go to Lowes and buy their 50 lb. bags of play sand. After laying the sand out on a sheet of plastic to dry, you need to filter it through some window screen material to remove the larger bits that would clog the blasting tip.
I set up a work area to catch and reuse the sand. I got three bags which was enough to do a table and six chairs, and the pot is full for the next job. The fan blows the ultra fine dust away, but it's very important to wear proper breathing gear under the supplied blasting hood. Don't trust the cheapy particle masks, get a real respirator. Breathing the dust for extended periods can cause silicosis (think lung cancer) and there is no cure for it.
This is the deadman handle...note the metal plate sandwiched between the tip and the rubber backing pad.
and the replaceable ceramic tips encased by rubber. I found that using a coarse file to bevel the rubber tips slightly helped the flat plate sit more square and control air loss when the handle was released.
My compressor is a 60 gallon, 5 horse, two-stage unit and had no trouble keeping up with the demand but a smaller compressor will take more time to do the work.
Recommended pressure at the blaster is 65-125 psi. I set my compressor to 130 psi to compensate for the pressure drop through 100 ft. of air line. After the pot is filled and pressurized, I then opened the trigger on the deadman handle so just air was flowing. Then I slowly opened the media control valve on the bottom of the pot. If you open the media valve first, the feed hose will clog. The amount the media valve is opened is critical, not enough and it doesn't remove paint/rust fast enough. Too much and you waste sand and slow down the blasting process from lack of air at the tip. The cleaning area is about the size of a dime, so be prepared for some long days if you're doing a large project like this one.
before and after...
After a few hours of use the metal plate/rubber backing piece that shuts off the media flow gets worn and needs to be replaced. You can tell because it keeps hissing air even with the hande released. Replacements are available through HF for $1.50 but I found that removing the metal plate from the rubber backing and turning it around, using two-sided tape to reattach, you get extended use from each one.
Three phases of use...
Overall I give this blaster a good review. If you fail to use dry sand or don't control the flow of material well you'll be unhappy, but for rust removal on items too big to fit in a traditional blast cabinet I think this is a great tool to have around.
before and after...
