HEI
73c20jim
Tombstone, AZ
OK, I have read all the forums and wiring diagrams, and just need confirmation.
The only wire I need for the HEI is a wire from the run circuit in the ignition switch.
This wire is used for both starting and running.
I know the second terminal on the HEI is for the Tach.
Am I correct?
82sbshortbed
Fuckemall!!
SE Texas
Doug
1500 shortbed, 1500 longbed
Yesir I believe you are. I only have the 12v battery wire to mine. I don't have a tach in mine yet.
Charlie
Euless, Texas
Don
Cheyenne 10 LWB
350/TH350/AC/4 BBL Quadrajet
Correct. I connected 12v to one of the IGN terminals on fuse box and the other is for tach.
73c20jim
Tombstone, AZ
OK... Looking to get a new HEI cap and rotor and a found that complete HEI dizzy is about $50 bucks. Also HEI dizzys for much more. Are these $50 dizzys any good??? Or you get what you pay for???
1987 GMC Jimmy
Automobile Hoarder
Mississippi
Jesse
V1500 Jimmy
My suggestion would be to go for the AC Delco remanufactured Delco-Remy distributor. It should with everything except the cap and rotor, and you can order all that from RockAuto. That one (88864775) is $98 plus a $50 core. There’s a 5% discount code on the preferred vendor section, but I would copy that part number and see if anyone else has it for cheaper. Personally, I would stay away from the cheap stuff because crappy HEI parts can go out like a light, and I don’t want to be looking for a place to pull over a 33 year old car in six lanes of rush hour traffic.
dvdswan
Port Orchard, WA
Dave
You do have 3 wires from the distributor itself that plug in the cap also. the 2 outer plugs are for +12V and Tach.
yevgenievich
Viktor
sad
very sad
less sad
I used one of the cheap units and it worked fine for my application. But I did end up selling the truck eventually.
Camar068
10 yrs Air Force
They are worth it. Search the forums for "skip white". You'll see plenty of good reviews. Come with cap/rotor/coil for ~$50.
I had one in mine for a few years with no issues.
EDITED: forgot about the lifetime warranty. Don't know about that as I didn't have any issues.
https://www.skipwhiteperformance.co...0-383-super-65k-hei-distributor-6500-r_89699/
73c20jim
Tombstone, AZ
Looks good. Will investigate. Thanks for tip.
78C10BigTen
pennsylvannia
C10 BIG TEN
Sure looks like a pretty sweet deal! Got me interested lol
MikeB
North Texas
If you go with a $50 no-name Chinese unit, then buy a spare and keep it in the truck. Or buy Proform or GM and be done with it.
78C10BigTen
pennsylvannia
C10 BIG TEN
I already have a spare distributor with wires and carb and fuel pump all in the tool box in the truck. I tend to be prepared.
85 CA SIERRA 1500
So. Cal
TRACEY
SIERRA CLASSIC
T-ROD
Shelbyville, Ky
Travis
Watch out for the newer ones, they're good but need a ESC module (electronic spark control) my truck has one, they made two different ones, external and internal coil, I know your looking for the internal coil one, but if it's for anything above maybe 83-84 it's probably going to be one of the ESC dizzy style ones, they can be configured to work but it's for like on yours or mine in years where they used a ESC module behind glove box, NB I have an 85 K10 with it also, I still use it though, it helps with the timing if the vacuum advance goes to far to quick it detects spark knock and vacuum pressure and it backs timing off by I think up to 15 degrees for a second while RPMs catch up or if knock sensor detects a spark knock, it seems to help a bit, but just figured it might be helpful if you didn't know that, but either can still work right.
Obullard74
