5th
- Oct 3, 2015
- Wasaga Beach
- Sean
- V1500
Hi folks, about to spend alot of time googling and thought I'd start here.
Was out for a drive yesterday, noticed the motor would drop off at 80kph as if I had taken my foot off the pedal. Got it up to 90kph and the problem seemed to have corrected itself.
Went for a drive today, about 2 hours. (I always baby my baby, no hard wheelin' or burnouts)
Shut her off, went in the store, came out. Started it up n' she ran at full idle.
With my 86' sub I knew about the choke, give it a solid shot of fuel and it would start to idle normally. So I tried that and it didn't work. Figured since this sub is a 91' with the TBI maybe it doesn't have the same choke shut off.
Got about a block from the store and the engine stopped as if it had run out of gas.
Had to hold the pedal to the floor to get her started again. When it started I got a big plume of black/grey smoke out of the exhaust.
Pulled over and it died on me again.
Checked the antifreeze, no discoloration. Oil was only about half full, which was odd.
Checked the tail pipe and the inside is coated with oil. (would explain the black smoke)
So head gasket? Did I just get lucky enough to catch it in time?
