Hacked up stereo opening repair - '81 Scottsdale C10
blk81
I would like to install a "factory style" stereo, but the opening has been hacked for a single DIN. I saw the thread where you cut a piece from a donor truck and bolt it in, however, I seriously doubt finding one around here. Is there a kit Metra or some other manufacturer makes nowadays that will fix this? Should I just tap out and install a single DIN and be done with it? I really wanted the stock look if possible. Everything else for the system is installed. I just need to decide on the head unit. Any advice is appreciated.
mrghostwalker
Connecticut
K10/20
I had the same problem with my 83.
I noticed the edges for the dash were in such a way that by slicing out a section of dash from my parts truck I was able to replace a section of the old dash in such a way that it doesn't show the repair.
blk81
And I guess this is the "meat" of my question/problem. I would prefer to repair it like you did, however, I doubt there are any donor trucks around here. The kits I've seen like the one listed above by TPISly-c10 basically fix the dash bezel that's been cut so it looks better, but what about the metal section of dash that has been cut out behind it? The nuts for the shaft knobs tighten to this, so in order for the radio to be secure, I would think you would need some metal there. I have a brand new dash bezel ready to install that's not modified, so no need to fix that.
blk81
Thank you for the link. Do you think this part would work to replace the metal section of dash that's been cut out? Maybe line this part up, drill it out and secure it with some machine screws/washers/nuts? I have a new dash bezel to replace the modified one that came in the truck. Whatever I end up doing, thank you all for the help. I'll post pictures of the process and finished product.
TPISly-C10
Boucherville QC Canada
Sly
C-10 shortbox
LQ4 6.0L
look a this video :)
blk81
Thank YOU! This will work! I just won't need the faceplate since the new dash bezel will cover the front. It's going to look just like I want it to.
johnalen76
