Ground locations
Trevor Terpak
Weeki Wachee Florida
Trevor
R1500
Hello, I'm new here with limited experience with electrical. I am assuming i have a bad ground connection that has caused my dome light, horn and radio to stop working. I have searched for a diagram showing the locations of the ground straps and cant seem to find anything. My Truck is a 1990 R1500 suburban 350c.i.
Thanks in advance.
chevytech87
Tomball, TX
Brandon
GMC R1500
Make sure you check fuses too, horn and dome light often share a fuse
SirRobyn0
Rob
I will echo what others have said, check the ground above the brake pedal, check the fuses. If the truck is new to you don't overlook the fact that they could be all separate problems, that the PO simply did not address as they occured.
3dbello
