Grille question
Wracks81
TN
c10 scottsdale
I have an 85 Scottsdale. Will an 87 or so 4 headlight grille fit my single headlight truck? My turnsignals are under the headlights,but i can remove them from the other grille.
animal
Lee
c10 silverado
350ish
You need the 4 light core support as well. Most try to find one from a donor that has the headlight buckets and associated hardware.
1987 GMC Jimmy
Automobile Hoarder
Mississippi
Jesse
V1500 Jimmy
Well, a couple things for you... First, you've got an 83-84 grille. The next style is the 85-88 grille, which is the one my Jimmy has. The last style is 89-91, which looks like an early GMT400 grille. Second, if you're switching from a single headlight configuration to a dual headlight one, the radiator core supports are different between those setups. So no, it's not a straight swap.
If it's just the grille you want to swap, then yes, it fits.
Wracks81
TN
c10 scottsdale
yes bucket,that was my main questions. not changing headlights,i just have another grille in the shop layin around. new to these trucks.
Wracks81
TN
c10 scottsdale
truck in the pic is not the truck I'm working on......
soliddrummer
