Got this green truck...1985 CUCV M1028
ridenby
William
M1028
6.2L
Acquired a 1985 CUCV M1028. Pretty nice truck,changed it to 12V, Put some ORD 4inch springs up front,shackle flip in rear. Couple
pics of what I started with.
ridenby
William
M1028
6.2L
After lift and some 37" tires.
ridenby
William
M1028
6.2L
Rode around a little. Changed to screw on fuel filter, couple of other little things. DIY4x4 shock mount in rear. Winch mount front .
animal
Lee
c10 silverado
350ish
Nice :waytogo:
ridenby
William
M1028
6.2L
A few more days went by...put a topper on,went for a ride with a bunch of jeeps and some toyotas. Added a little camo too.
That's a cool truck !!! Welcome to GMSB !!!
ridenby
William
M1028
6.2L
The jeep ride was interesting. Found a couple of weak links. Changed trac loc to Grizzly locker, axles to RCV, hubs to Yukon hardcore.
Frankenchevy
Proverbs 16:18
USA
Square
CUCV
Small
Looks good! Makes me wish mine still had the green paint.
77 K20
Montana
K20 5" lift
HT383 fuel injected
Looks awesome!
Can you provide more details about your lift? Did you shift your front axle forward at all? For the rear axle I'd imagine you did the 4" shackle flip, but did you have to shim the rear axle?
Any details on the wheels? (size, specs) Looks like maybe you are using spacers in the rear?
ridenby
William
M1028
6.2L
Looks awesome!
I used ORD 4inch front springs,shackles etc. The center pin is moved so the axle is 1inch forward. I used a 6 degree shim in rear with a shackle flip. The wheels are Trailworthy Fab recentered hmmv wheels PVC inserts for the double beadlock. No spacers.
87R10_Cruising
