- Aug 3, 2010
- Usually not in Ohio
- Andy
- '77, '78, '79, '84, '88
- K5 thru K30
What year is your truck? Not sure you ever told us.
got mine all mocked up, got a 4 spd saginaw bheind it, sitting a tad far back as the vave cover hits my heat only box. I could get another 1/4 inch out of it according to my mounts, think the trans crossmember is holding it back, have to check it out. Yes it's solid mounts, solid 4.3 frame pads, flipped and changed sides and stock gm block mounts. I had to try and see if it would work and it does. I will most likely get some poly block side mounts to avoid vibration issues, and to me it needs lowered a tad. I done ruined one set of block mounts trying to shorten them up, went too much.
Plans may change again from a complete frame off resto to a quick get it done and on the road deal depending on what hppens with my other truck, right now looks like frame off still. Going to trade wheels for some chrome rallys here soon maybe. I cleaned up the ar23's and look nice might keep and run. not much else changed or going on.
