Getting to much fuel
seabee
South Carolina
Lee
Need some help on this , 1987 R10 305 TBI . Runs great but it’s getting to fuel . I keep getting code 45 running rich, I’ve replaced TBI with Holley 502-5 . When with GM TBI would get Code 45 . Truck is getting 6-7 MPG . Only code 45 no other codes. New fuel pumps in both tanks ,checked pressure at filter getting 15 psi .
Change o2 sensor 2 times and replaced it with 3 wire . Replaced ECM , 2 sets of plugs . Replaced plugs wires , cap , rotor , every sensor and module have been replaced MAP , IAC , coolant sensor, grounds have been replaced. What could be causing it to run rich . I’ve turned down pressure regulator on Holley TBI after talking to their tech department. Is 15 psi too much ? If I unhook IAC to adjust base idle engine will run at 1800 rpm . If I reconnect IAC it will idle back down to 800 rpm . Any help will be greatly appreciated. Thanks
fast 99
Spokane, Washington
What is the manifold vacuum? Fuel trim is primarily controlled by the MAP, 02 is secondary. My first thought is a stuck or leaking EGR.
seabee
South Carolina
Lee
Manifold vacuum 18-19 , Egr is removed and blocked off . Replaced map sensor 2 times . Is 15 psi too much for TBI ? Holley said it’s should be max 12 psi . Thanks
Why are you asking us if holley already gave you the answer? Yes, 9-12psi is correct for all TBI before 94-95. In 94-95 the 454 TBI went up to 30psi, all others stayed at 9-12.
seabee
South Carolina
Lee
Sorry did not talk to Holley till after I ask the question. But thanks for your answer
Vbb199
B-rate Hillbilly Customs
Salisbury NC
Vince
89 Suburban R1500, 79 C10
Throw that holley chit in the garbage.
They're notorious garbage and not a replacement for gm tbi
gmbellew
Kansas city
glen
suburban 1500
I am also having a rich condition. but only at idle, in park with no accessory load.
I think 9-13 psi is the spec fuel pressure range. seems like you may be over pressured or have a leaking fuel pressure regulator.
I am waiting on a pressure gauge to check my pressure
gmbellew
Kansas city
glen
suburban 1500
also, to check base idle without IAC, you have to force IAC closed and then unplug it. or remove it and otherwise plug the passage.
Vbb199
Salisbury NC
Vince
The rubber diaphragm probably just went bad on the OEM tbi, or the injectors aren't spraying in an even conical pattern and dribbling.
All common TBI problems and can be resolved for less than 50$
Edit: curious sake, what's the engine vacuum in/hg currently ?
You can tap into the intake manifold behind the TBI and measure this.
fast 99
Spokane, Washington
The OEM TBI system is very basic and dependable. Put it back to stock and start over. Yes 15 PSI is high. Enough to cause that problem? don't know.
mshawn
Malvern,Ar
Micah
c10,jimmy,k10
EGR leak!
fast 99
Spokane, Washington
EGR leak!
He said the vacuum was about 18 pretty normal. EGR issues will usually lower it substantially.
edit, be sure and check the grounds on the thermostat housing. Also check the AC [not DC] voltage at the battery engine running. If near 1/10th [.100] volt that's too much. Excessive AC could cause all sorts of drivability issues.
mshawn
Malvern,Ar
Micah
c10,jimmy,k10
Vacuum is at 18 hg to the EGR or idle vacuumn of the engine is 18 hg? Maybe I missed this
88SQDRW
