Gear Ratio Selection
vicnation
NC
Tristan
My '76 K10 has the original 350/350 and NP203. I plan to upgrade the drivetrain but I need advice on what gear ratio to use. The current gear ratio is 3.07 with a Dana 44 and a 12 bolt. I will be installing a 383 pushing about 420 lb ft torque mated to a 4l80e and an NP205. I will be running 33" tires as well.
I would like the truck to have good launch from a stop and be able to cruise easily at 70 mph. What gear ratio is recommended?
Thanks...
yevgenievich
Viktor
sad
very sad
less sad
Probably 4.10 would be better match with 33" tires and a 4l80e. Can check online gear calculator for your comfartable cruising rpm
gpmorgan
Tupelo Ms.
greg
I recently installed a set of 410s in my son's tahoe with 35s. It was a great improvement.
Honky Kong jr
Super Sarcastic Man
Denver,PA
J-me
Lil BB 407
What they said....4.10s.
4WDKC
Southern Florida
Kacy
My truck had 342s and 33s with 700r4 when I bought it, It would have to drop out of over drive to speed up on the interstate and when there was any type of incline, I swapped to 410s and 315/70r17s and the truck is much better. I bought the wheels and tires used so when they need replaced i will be going back to the 33" height.
vicnation
NC
Tristan
Thank you for your input. Really appreciate it.
Ohiokm
