Gauges
84chevk10
Anyone ever installed 2 5/8's gauges in place of the stock ones? I was going to mount them under the dash but I've seen where put aftermarket in their dash panel. Mine are mechanical and I don't want to screw up a good cluster. Mine has the gauges plus the clock. Also need a 3 spd shift indicator if someone has 1 for sale.
1973c10
Don
I did mine like this don't know if this is what your looking for
84chevk10
You changed all of them. I've seen some keep the speedo and fuel gauge. Wondered how they done it. Yours look great though.
BiggG74
Pasco Washington
Gilbert
GMC
What brand of gauges are those? They look good.
1973c10
Don
Speedway Black 6 Gauge Set
but I used a autometer fuel gauge the one that came
in the Speedway kit didn't match my fuel sending unit ohms
there not a bad price and look good
84chevk10
Did you speedo cable hook up?
This was in my 82 Longbed
74 Shortbed
That's a nice looking panel.
84chevk10
Yes that is nice. I really like the white gauges.
TRAZOII
Phoenix
Anthony
K10 Sub
Where is there a write up for this?
Sent from my VS990 using Tapatalk
Craig 85
Nashville, TN
454/TH-400/NP205
Sorry I don't have any pictures, but I had an 80 crew cab C2500 around 1995. It had the idiot lights. I added Autometer mechanical gauges. I don't recall the size, but I know they slid into the factory gauge cluster (the blue piece behind the bezel). I may have had to trim the depth of the gauge pods or the back of the bezel so they fit flush. I was able to sneak the hoses/wires out the back by removing a couple of the dash light holders so the curcuit board would move. I used the green filter over the gauge bulb making it look factory.
Old Painless
Santa Clara County
Reid
C1500
6.0 LQ9
Cant say for 2 5/8 but the 2 1/16 auto meter fit pretty well. You'll have to hack the back of the cluster for these to fit. I love how they sit, can't say the same for the big tach/speedo as the angle is too steep to see the top numbers.
It may be pretty difficult to keep factory gauges as there is a maze of laminated circuitry behind the cluster if you do any hacking. I had to completely omit the circuitry back there, not sure if you want to go all the way on that.
87ScottW
