AyWoSch Motors
The Parts Guy
- Nov 6, 2020
- New Mexico
- Ayden
- K1500 Sierra
- 350ci V8
So I recently got my 86 GMC running and driving again. After driving around a bit, i relized some of my gauges don't work.
Speedo is working fine, except for the fact that when i go backwards the needle goes backwards. No idea why. Oil pressure seems to be working fine, reads 40ish on cranking 60+ when running.
Now the issues, are with the others. The temp gauge has never worked, the volt guave used to, but is now at 0. And the gas gauge has never worked well, but it was consistently off. 1/4 tank on the gauge was empty and quarter over full on the gauge was full, but now it kinda bounces around, seems to be in a different place every time.i figure bad sending unit, but idk.
And while were digging into gauges, my 4wd light has never worked, and the choke light is always on.
My question is, how to fix these things.
Could be wiring, not sure everything under the hood was hooked up right after the engine swap (rod knocking 305 to L98 350 for those who don't know). Im clueless on how to fix it. All i know, is that the alternator is charging, the engine is getting hot (i have a temporary temp gauge under the hood), it has about 6 or 7 gallons of gas in it, but id really like to keep track of it all real time and accurately.
I have a bunch of extra gauges, and extra gauge backers, but i suspect thats not the issue.
Any ideas or insight would be appreciated, thanks.
