Fuel questions! help please
wheelerboy12
Dundee, OR
jeremy
i have a few question about my truck, i just bought a 1978 k10 4x4 with a 350 and 4 speed granny tranny, i was wondering about how many miles per gallon im going to get, also what are some things i could do to boost it, ive changed my plugs and wires, and new bettery cables, ive read that an elec fan can boost 2-4 mpg's but can any one confirm this? and has any one had any luck with an elec water pump? ive only had the truck for a few days and im already in love with her and want to be able to afford to drive her! also my fuel gauge is lieing hard core, i only have 2 gallons in the tank yet it says full, any one know how to fix this? i really could use some help! thanks.
NO, you will not get 2-4 better changing to E fans. You may notice a bit more horsepower to the ground and might gain 1/2-1 mpg better but I can imagine 2-4. Once the old fan is moving, it's not much to keep it moving. We do need all the help we can get with mpg on these older trucks compared to newer ones. If you're getting an avg of 15mpg in a K10 be satisfied. Depending on tire size, lift and all things considered, you might do better, might do worse. Manual trans drivin correctly is a plus in the mpg area. But, a good working 700r4 if you're willing to baby it to keep it alive, will probably trump your SM465 on the highway sicne it has OD. And that's not always true either. If a guy is running 3.08's and a 700r4, I don't see OD doing him much good. He'll be able to drive 80 but his mpg isn't going to be much better than yours doing 65 with 3.73's
Jims86
Patterson,Ca
K10 Suburban Silverado
5.7 TBI
Welcome to GMSB!
First and foremost, a tune up is in order. Plugs, wires, Cap, rotor, pcv valve..all those items should be AC Delco, no substitutions.
While you have the cap and rotor off, make sure your advance weights move freely...maybe wipe that stuff down with WD40 or PB Blaster.
new air filter, wix or Napa gold recommended.
At least a can of sea foam or Berrymans B-12 in the tank. put a whole can in with the few gallons in your tank now...run it super concentrated.
Tire pressure, at least 35PSI.
Is the truckmall stock? Post engine pics with the air cleaner off, and pics of the truck its self....Pics are worth at least 1.5 MPG on the forums!
wheelerboy12
Dundee, OR
jeremy
10-15 is AWESOME! right now i drive my dads tahoe and she gets maybe 10 on a good day and i considered her my gas saver... im more concerned with the lack of my fuel gauge working though, i dont mind puting gas in it, i just want to know how much i have, ive already ran out of gas twice once on our way home the day i bought her and once trying to drive down the block to show my friends dad my truck bc he wanted to see it. amd ill get pics ASAP!
wheelerboy12
Dundee, OR
jeremy
alright, heres the only picture i have of the engine, ill get a better one today if needed
and here is the truck itself right after i got her painted,
Hey Look, It's an Inline Slant 4 with a 4 barrel Carb. And I thought Dodge fugged up bad !!!
Or you any good at reading schematics and tracing wires? We've got help posted here for fuel guage wiring. You're not the first to have guage issues.
wheelerboy12
Dundee, OR
jeremy
thats a 4 barrel carb?!?! i thought it was a two.... and i can try i tried searching for fuel gauge issues can you point me two the thread with the info please?
Most gas tank units consist of two parts, the gauge mounted in the dash and a tank sender mounted in the tank.
The gas gauge, often located in the instrument cluster, consists of two small coils spaced 90 degrees apart with an armature and a needle placed at the intersection of the two coils. A dampener is also located on the armature to prevent excessive needle movement on rough roads.
The tank sender unit is mounted to the outside of the gas tank (with a float on the inside, of course) and is made up of a metal housing that contains a rheostat (which is simply a resistance unit), and a brush that comes in contact with the resistance unit. The opposite end of brush unit is attached to the float arm located inside of the gas tank. The movement of the float arm is controlled by the amount of fuel in the gas tank. The variations in the amount of fuel in the tank cause the arm to move. This changes the resistance of the tank unit, changing the amount of current at the gauge unit coils, which in turn moves the needle located between the coils.
The most common cause of gas gauge trouble is a poor ground, especially at the tank sender unit. It is important that all wiring connections are clean and tight, and free of dirt and corrosion. A poor ground or loose connection to a gas gauge is just as likely to cause problems as loose or dirty battery cables assuredly will with your starting system.
For example, if the gas gauge needle remains on empty when the ignition key is turned to the "on" position and you are sure the gas tank is partially full, battery current may not be reaching the gauge. To check further, connect a jumper wire between the ignition switch and the dash gauge. If the gauge now works, replace the defective wiring between the gauge and the ignition switch.
If the gauge needle remains stuck in one place, try turning the ignition switch off and on several times in succession. This will allow you to determine if it is the dash gauge or the tank sending unit that is defective. If turning the ignition switch off and on (a half-dozen times is a good test) does not seem to help, and you've verified that the dash gauge is receiving power, try the following troubleshooting steps:
A functioning sending unit will have a high resistance when the tank is full and a low resistance when the tank is empty. If the gauge reads higher than it should, make sure the wire attached to the electrical terminal on the tank sending unit is making a good ground connection. If necessary, clean the connection and reinstall the wire to the terminal, then check the gauge operation. If that didn't fix the problem, use a jumper wire to ground the electrical terminal on the tank sending unit to the tank unit housing (leave the wire to the gauge connected to the tank unit). Turn the ignition switch on. If the gauge reads empty or below empty, the sending unit is defective.
If the gauge still reads high, try grounding the tank unit electrical terminal to a clean portion of the frame. If this brings the gauge to empty or below, the tank unit is OK, but there is a bad ground between the gas tank and the body or chassis (or less likely, between the tank unit and the gas tank). Either way, find and correct the bad connection or merely run a permanent jumper wire from the frame to one of the screws holding the tank sending unit to the tank.
If the gauge still reads incorrectly, the wire from the tank unit to the gauge may be faulty. Check by using a jumper wire to ground the tank unit terminal on the gauge (the one not connected to the ignition). If the gauge now reads empty or below, the problem is in the wire leading to the tank (or its connection to the gauge). If grounding the tank terminal still doesn't cause the gauge reading to drop to empty or below, the gauge is faulty.
When the gauge reads lower than it should, check at the gauge by disconnecting the wiring from the tank unit. Turn the ignition on and if the needle reads full or above, the gauge unit is probably good and the tank unit or the wiring leading to it are probably the problem. Reconnect the tank unit wire to the gauge before proceeding.
The next trouble-shooting task begins by disconnecting the wire to the tank sending unit. If the gauge still reads full, there is likely a short to ground somewhere between the sending unit and the gauge. Look for worn insulation allowing the wire to contact the body or frame. If the gauge reads full or above with the wire disconnected, the problem is in the tank unit rather than the wiring. It could be an electrical fault, or the float may be stuck or may have sunk because of a hole caused by corrosion. Remove the tank sending unit and check it. If the float is bad, you'll likely hear gas sloshing around in it or see gas dripping out. If the float is OK and the float arm seems to be swinging freely through its full range, replace the tank unit.
Ground the gas tank terminal post of the tank sending unit using a jumper wire. If the dash gauge now reeds empty, the gas tank unit is defective. If the dash gauge needle fails t move, the dash gauge is defective.
If the gas gauge works, but reads lower than it should, check for defective wiring between the gas gauge and the tank sending unit. Also check for a poor ground at dash gauge and the sending unit by using a jumper wire.
If the dash gauge reads empty when the tank is actually half full or greater, the wiring between the dash gauge and the tank sending unit is defective. Disconnect the wire at the gas tank sending unit terminal. If the gas gauge reads still reads empty, the dash gauge unit is defective.
Phew......
Jims86
Patterson,Ca
5.7 TBI
Phew......
gawd Damn! Go ice your fingers down now!
Is that the PCV nipple that is plugged on the carb.
A picture around the carb area would be good. And that aftermarket ignition stuf.....Blaaaahhh. Gotta fix dat!
Jims86
Patterson,Ca
5.7 TBI
What the heck ist that silver rod thingy pointing out from the throttle?
guitarfreak235
Spartanburg S.C.
Andrew
k10 c20
im not sure if they had em in 78, but check inside your air filter and see if there is a flame arrestor. it looks like a smaller metal air filter. if you got one take it out! that thing is a major restriction
Huh??? :popcorn:
wheelerboy12
Dundee, OR
jeremy
Phew......
wow, thank you so much haha ill be looking into the fuel gauge tomorrow,
aaron06
