fuel pump question
spanky55amg
I'll give u $5, a hardy handshake, & 5 fish sticks
Dallas, TX
Spanky
C10 Short Fleet
V8
The fuel pump I just took off has an inlet and outlet. The fuel pump AZ has three connections. One looks like a vacuum hose connection.
which is correct?
Why is there a vacuum connection?
can i use this one, if now what should I put on?
spanky55amg
Dallas, TX
Spanky
C10 Short Fleet
V8
On some quick research, the one that I have on the truck looks like it might be for a 2nd gen or early square body.
if so, why the vacuum port?
spanky55amg
Dallas, TX
Spanky
C10 Short Fleet
V8
So maybe its vapor return? **** it, Im going back to AZ and getting one without the vapor return.
spanky55amg
Dallas, TX
Spanky
C10 Short Fleet
V8
As per one of the Chevelle sites, usually AC vehicles came with a vapor return. The return is too small, .060" for liquid to come out and only vapor to come out. They also put them on vehicles that needed the return if they had a lot of vapor lock. Seems like plenty of guys are running this style without the return with no issues. They capped it off. So thats what Im going to do I guess. Meh.
spanky55amg
Dallas, TX
Spanky
C10 Short Fleet
V8
If I didnt need it on the road in like an hour, Id deal with it... what was the saying about necessity and ingenuity?
jake wells
Can i be me?
Brownsville Kentucky
jake
custom deluxe 10
put a hose on the vapor return and plug the end with a screw or bolt.
spanky55amg
Dallas, TX
Spanky
C10 Short Fleet
V8
Even better. The old pump must have been an old rebuild able pump. I'll take a pic of it tomorrow. So the fittings to it were smaller. Funny because at one time, I was just going to order a replacement hard line from the pump to the carb but that wouldn't have fit. So I had to run to AZ anyways and just swapped them out a fuel pump for a 72 C10 w/out AC. And it was a two port. But I still had to buy a 3/8 npt transmission cooler nipple. Oh well. Job done.
jamba
Ruhtinansalmi, Finland
Jarmo
Blazer K5 Silverado
6,2 Diesel
What about just opposite situation? I just got new mechanical fuel pump, it has 2 connections. The one i have on side of 305 has 3 connections. Can i just ignore that return line?
82sbshortbed
Fuckemall!!
SE Texas
Doug
1500 shortbed, 1500 longbed
My 82 c10 has 3 also. I have saddle tanks on it. So I'm pretty sure it's got one intake for each tank and then one outlet to the carb that the hard line is hooked up to. It's the one closest to the engine.
You should be fine if you plug the line and the pump nipple. I’d say try to get the correct one, but I imagine it’s not always that easy to get parts over there.
PrairieDrifter
North Dakota
Mason
350, 350, 350, 350, 350
If I’m not mistaken I believe only one of those is an inlet, one is up to the carb and one is a vapor line. On dual tank setups I believe the two tanks go into the diverter valve separately and then a single line comes out of the diverter and goes to the fuel pump.
My suburban has two nipples, one for the inlet, one for the vapor, then it has one threaded hole for the hardline up to the carb.
jamba
Jarmo
Blazer K5 Silverado
6,2 Diesel
Thanks! Yep, those pumps don't grow in trees here..
I won't swear to it, but I think the 3 fitting pumps had the small return, and it was for a vapor return vent back to the gas tank on models before Canister Purge came about.
alysco
