- Mar 5, 2014
- Kansas City, Missouri
- ryan
- r10
On an '87 R10 with dual tanks can I put an external power fuel pump in front of the selector valve? I was thinking of installing the pump in the engine bay but probably not a good idea due to hear and the distance from the tanks to pump. Ditched the tbi setup and all the wires with it. No way now to kick on the fuel pumps inside the tanks unless I can hotwire them to a switch but as far as I knew the pumps needed signal from oil pressure to kick on. Can that just be bypassed? I have a mr gasket 12s pump just to get me running till I get the rear tank installed.
Will the external pump still flow enough through the selector and the pumps in the tank? I'm really trying to avoid pulling the tanks down just yet until I get the rear setup done. I also want to use the factory return line with a regulator that has a return spot on it.
I've already got the pump and trying to avoid extra work and $$$ if at all possible. Any help or advice much appreciated.
