Fuel pump issue
Stepside Billy
Lake Carmel, N.Y.
Billy
I started my truck to go to work yesterday. I always wait a second or two to hear the pump start. Fired right up, ran for 30 seconds then died. Went to start her again and didn't hear the pump. Pump or relay shot? At least it happened here at home and not at work like my old Dodge!
Stepside Billy
Lake Carmel, N.Y.
Billy
My Service Engine Light did come on a couple of days ago. Did the wire trick to the OBD. Came up as code 24 but says to disregard this code and check TPS setting. Would this cause my problem?
smoothandlow84
I'd rather be draggin' frame
Steve
1500 r10 pavement scraper
Check the fuse too. Mine popped and although it woukd crank, no fuel pump priming was heard. The last issue I had was when I switched from the drivers side tank to the passenger side tank with the engine running. The motor sputtered and died. The problem was my fuel pump went out. Not bad for a 30 plus year old fuel pump. If it is in fact a bad fuel pump, be sure to also buy and replace the intake screen that attaches to the bottom (intake) of the pump. When these filters fail, particles of the screen become lodged in the pump also causing eventual failure. I found it easier to drop the tank, rather than slide the bed back.
Stepside Billy
Lake Carmel, N.Y.
Billy
I have a stepside so I have to drop the tank as the pump is mounted under the cab. The pump in my Dodge had **** the bed at work. I was able to grab a service truck, take it home and get my air compressor and tools. We have a boom truck at my plant so it was put to good use pulling my bed off!
Stepside Billy
Lake Carmel, N.Y.
Billy
Is there a fuse in the engine bay? I checked the fuses in the cab but they were ok.
smoothandlow84
Steve
The fuse should be under the dash. It took me awhile to locate it. My fuse blew scratched my head for a bit and passed it off as just an electrical gremlin (had quite a few during the restoration). I finally figured out that the fuel pump in the passenger side tank was locking up. When I pulled the pump.....yeah...it was roached! Now I am back to having two functioning tanks. Thank goodness that the drivers side tank kept me on the road. Previous owner did quite the hack job when he ATTEMPTED to restore this squarebody
Stepside Billy
Lake Carmel, N.Y.
Billy
My truck had duel tanks but one of the p.o. removed the passenger side tank. I eventually want to get another one.
Stepside Billy
Lake Carmel, N.Y.
Billy
Where did you find it? I'm going to be working on her this weekend. Hopefully the weather cooperates!
smoothandlow84
Steve
Under dash...I believe its either the ECM, or ECMB labeled fuse. I pulled all thenfuses when mine would only crank, not start and replaced any that were blown. Best to keep extra fuses in the glove box in case you ever need some. If you prefer, you could also check for power continuity with a multi - meter rather than pulling them out . Luckily there aren't many fuses in the squares.
82squarebodyLS
