Fuel Guage issue. Not the average one.
Preacher141
Spearfish, SD
Terry
GMC K1500
Hey, y'all. Got an interesting fuel guage issue. Went through the usual...Ground check and grounding witre out from sender. 85 Chevy K10. Factory dummy light cluster, I got 5 volts to the left terminal until I put the guage in. Drops to .60. I got .5 on the bottom terminal until fuel guage is in, then nothing. I got 0 on the right terminal. Now I got another guage and reads the same in the factory cluster. If I put the guage cluster in from the other guage, Both guages if inserted will go to full if grounded. But, it will not register the fuel correctly and this is a budget build for a customer so not trying to swap the clusters. This one has me confused. Circuit board does not look messed up. Ground is attached. New wire to sender. Sender is a Holley Classic Fuel injection Pump and sender set up.
MarineOne
Western New York
Is it the correct ohm fuel level sender? There's multiple options
0-30
0-90
33-240
That's where I'd start?
Twistedwhisky
