front driveshaft on 84 issues
Preston
Mechanicsville VA
Preston
the transfer case is either too low or i have the wrong cross member the drive shaft is hitting the crossmember and can not get it low enough to bolt to transfer case. looks like the transmission mount needs a 2" spacer or something. i will post a few pictures. thanks for your help.
Preston
Mechanicsville VA
Preston
Is this a transmission mount? If so this is my problem I used what I thought was the transmission mount and need to bolt this to that. Oh well nothing like putting something together that someone else took apart.
Preston
Mechanicsville VA
Preston
dvdswan
Port Orchard, WA
Dave
How about a picture of the crossmember, the driveline where its hitting, and which one of your trucks are you talking about?
I only ask as the x-mbr has what looks like two holes inside the where the 2 studs come through. They don't look large enough for a bolt. Also, I don't recall a x-mbr having a slot for the mounting studs.
They did have trans mounts with the single bolt in it but IIRC that was for a manual trans. Your mount may have collapsed if your trans was leaking on it.
Preston
Mechanicsville VA
Preston
Solved my problem I used the mount in the first picture and bolted it to what I thought was the transmission mount and everything bolted together
Preston
Mechanicsville VA
Preston
Thanks for the help this is the first 4x4 I have put together and being 66 yrs old I may have the beginning of old timers. Or something
Preston
Mechanicsville VA
Preston
This is a 84 with a 85 350 and transmission and transfer case from a 89 Surburban I bought the truck from a guy that was trying to put a 5.3 in it I bought the motor transmission and transfer case from the 89 Suburban and the motor was locked up so the engine was out of my 86 and had a blown head gasket so we are going to see if it all works, we will see.
i see a very tall intake. is that for low end power?
dvdswan
Port Orchard, WA
Dave
FYI, your crossmember should look something like this...
Preston
Mechanicsville VA
Preston
thanks i have parts and pieces everywhere just pulling what i have avalable, that intake came off an early model Corvette
Preston
Mechanicsville VA
Preston
I have a different crossmember but i believe it will work stay tuned for further updates. this is kind of like the Johnny Cash song one piece at a time, and time will tell
You currently have a 4x4 "short foot" mount with a 2wd mount bolted to the bottom of it. Your crossmember is the flat type that uses a "tall foot" style t-case adapter, which uses different style mounts altogether.
You definitely have a Johnny Cash thing going on, but it seems like it all works as it is.
nathanjohnson85
