front driveline
Roughneck714
Vacaville
6.2 Diesel
Whats this transfer case?
GreaseDog
Elkhart, IN
1977 K20
1980 K2500
205. What's the front output look like? Flange or yoke?
Roughneck714
Vacaville
6.2 Diesel
i believe this is a flange Correct?
Roughneck714
Vacaville
6.2 Diesel
What was the 4 speed manual called ? i Found these numbers on the side
GreaseDog
Elkhart, IN
1977 K20
1980 K2500
Well, my driveshaft won't work then, it's for the yoke style front output.
So you have a Dana 60 front axle with a 1350 U joint up front??? C4 maybe able to confirm that. For a quick patch job, I'd imagine you could get by with a 1/2 or 3/4 ton front driveshaft and use a combo U joint to the front axle. The SM465/NP205 is not all that uncommon. It's the 1 ton front Dana 60 that's got you by the balls I think.
Is your driveshaft completely missing or just in need of repair or what?
crazy4offroad
Equal Opportunity Destroyer
West BY-GOD Virginia
Curt
K-10
350/SM465/NP205
Some D60s have 1310 pinion u-joint, like mine right now, but upgradeable to 1350. If you're looking for the upgrade get a Dodge 2500 front driveshaft from a 2005-up truck. Not sure what the upper limit is on years, that's just what I heard. They have 35+ degree running angle of the double cardan joint, and 1350 u-joints throughout.
To be able to go with Jeremy's driveshaft you need a front output yoke from a 73-77 (maybe 73-76) truck. This is what I'm running now. You could use this front yoke...
http://www.dennysdriveshaft.com/p1307_cv_yoke_1310_series_10_spline_for_np205_front_output.html
...IF you have a 10-spline front output, which I dont think you do. I think 203s have 10 splines, 205s have 27 splines, you should count them to be sure. I went with the F*rd 32 spline front output shaft mod for NP205 so I could run rear yokes on the front. It opens up your options to 1350 and 1410 if you want to run much larger u-joints. Just have to swap in a rear yoke seal in the front to make it work.
Roughneck714
Vacaville
6.2 Diesel
Yeah hotrod. The dang scrap metal guy came round and snagged it. I jad it out replacing u joints. And he snaked it off the ground with the rest of the juck
MIDWESTCUSTOMS
