Front brake issue
SirRobyn0
Rob
@kenneth1669 I don't think it's the proportioning valve. Those valve proportion front to rear not side to side. So there is no way that it could make one brake stick. So let me give you a little info that might help.
If one side brake on an axle is locking up, the most common thing is for the caliper on the opposite side to not be working well enough. If one wheel is dragging and is not spinning freely then that side either has a bad brake hose or caliper.
If for some reason the rear brakes aren't working or are working poorly then yes that will make it easier to lock the front brakes.
So if that were my truck I'd adjust up the rear brakes, then put the wheels back on, with the rear end still jacked up I'd fire up the truck run it to maybe around 20 mph, and slowly press the brake pedal and see if the rear brakes are working.
Proportioning valves are cheap, once you replace it everything for the front is new, so why not, but I'm betting you have a defective caliper. Just because a part is new, rebuilt doesn't mean you can't have a defect part. If you decide to get one replaced under warranty, have them both replaced, just to be sure.
Bowers31
