Frame VIN?
scwaters
Chester Springs, PA
Sunny
K10 Shortbed 4x4
In previous posts I mentioned that my 76SWSB is most likely put together from several trucks. In reading other posts I saw a reference to a VIN on the frame. This would help me determine what exactly it is I have. If this in fact exists where on the frame would I find it?
Obwonkonobe
AZ
Ethan
C10 custom deluxe
Driverd side outer frame rail, by the trans cross member I believe
Frankenchevy
Proverbs 16:18
USA
Square
CUCV
Small
according to Keith that's a p/n.
I think both he and Craig said it's on the top of the passenger side frame rail behind the cab, about where the passenger side saddle tank sits. which means you'll have to pull the bed to see it.
  • Like
Reactions: evl
Obwonkonobe
AZ
Ethan
C10 custom deluxe
Ah my bad
Craig 85
Nashville, TN
454/TH-400/NP205
The VIN on the right frame rail is only a partial. Unfortunately, I didn't take a picture of mine when the bed was off so I can't recall what part of the VIN was there. I believe when comparing it to my full VIN it gave me the year and series (C/K 10/20/30) and part of the sequential numbers. My K30 has it near the tank, but most everyone else with a 1/2 ton has said its under the cab.
Keith Seymore
Motor City
Keith Seymore
4.3L
It will be the model year code, the plant code, and the sequential portion of the VIN.
Like "HF123456", where H=1987, F=Flint.
A = 1980
B = 1981
etc
K
87R10_Cruising
