Frame Rivet Replacement
greencountry05
Muskogee,OK
Skinny
V1500
Getting ready to pick up a spare Suburban frame to do a frame off restoration on my 4x4 Suburban. To take it to the powdercoater & to have it done right I need to take off all the mounts & have a smooth frame (no accessories/body mounts/etc etc). After I take off all of these rivets what is the best method for re-attaching them? Wasn’t sure if it’s gonna be bolts or find some gigantic aftermarket rivets lol. Anyone ever had to do this?
Just use quality grade 8 bolts. Make sure to use hardened washers and use the pinch type lock nuts, also hardened.
If you want to go the extra mile, you can drill everything out for 7/16 bolts, one at a time as you are fitting it all together. This eliminates any slop that you might have from using 3/8 bolts in the existing holes. On the other hand, if it's all getting powder coated, the holes may have zero slop due to the coating.
greencountry05
Muskogee,OK
Skinny
V1500
Thanks Bucket! I think my phone wigged out & posted this topic twice so you may have to delete the other thread. I may go ahead & drill it all out anyway. Definitely something to think about. Recommend lock tite on all them?
Grumpy
Saskatchewan
Daryl
I highly recommend using a reamer to finalize the bore of the holes.
You have inferred this is a project you wish to be done correctly, and I applaud you.
Unless you are replacing with hot rivets, any out of round condition will affect the soundness of the fastener. Remember to SLIGHTLY deburr/chamfer both edges of the holes, as this will reduce the probability of shunts along the edge of the bore.
Your fasteners MUST be of known quality. As much as I know they are horribly expensive, however for the frame fasteners I have only ever used Caterpillar brand or ARP Fasteners - and that is all I have used for the past thirty-plus years. Remember, the frame is the basis for everything you are riding on, and failures there are most often catastrophic.
Shooowee! Caterpillar bolts are $$$. They are indeed quality though!
shiftpro
BC Canada
shiftpro
350, 383, 454, 496!
Just weld it, eff the bolts.
JOKE ^^^^
Washington
I would think if you are going for a “done right” restoration, you would want all the factory looking rivets. And they are undoubtedly strong enough.
And you won’t have any worry about corrosion behind the brackets where they don’t get coated unless it’s already a rust bucket or planning to go bathe it in salt on winter roads. But those cases seem to defeat the purpose of a frame off powder coated frame resto.
greencountry05
Muskogee,OK
Skinny
V1500
The frame itself is in good condition & we don’t get much road salt here in Oklahoma. I don’t really care if it doesn’t have that “factory” riveted look. I just want it to be safe & secure when I put it back together. I’ve had my burb for about 8 years now & I just want to preserve it & take good care of it. It also helps to have a nice looking ride. Haven’t had a “hot rod” or a “custom” in many moons. It would be nice to have a cool vehicle again.
Washington
Maybe I don’t understand powder coating then. You can’t have parts attached to each other?
greencountry05
Muskogee,OK
Skinny
V1500
Yea they can touch. The reason for me taking everything off & then re-attaching later is just for sake of ease on the frame’s finish. If I were to leave the body mounts on I would not get a good coat. Not only would there be metal behind the mount without a coating it would also be difficult to coat in the areas around the mounts because of the goofy angles & tight spaces (faraday cage effect). I do powdercoat & Cerakote work on the side so I can do all the other pieces on my own. I just can’t fit a giant Suburban frame in my oven lol.
johnalen76
