fluid transfer pumps
CSFJ
So, the other night after work, I'm laying under one of the trucks refilling the rear diff. I was using the same suction gun that I used when I worked at a dealership, but being as I no longer had a hoist to work from the different position trying to refill the diff was kind of a pain in my ass. Especially with the residual mess the gun makes.
So my thought was this, does anyone know of a small fluid pump that runs off of 110v or compressed air, that would work well for gear lube and trans fluid? If I can find one I'd like to attach it to a reservoir of around 3-4 quarts. Something that would be small enough to fit under a vehicle on jack stands, and be able to be operated by one hand via a switch or valve.
I have seen several online, but none are really what I'm looking for. Don't really need one with evac capabilities, just something to pump new fluid in without having to refill it from multiple bottles and drizzle or spill it all over while laying under the truck.
Thoughts?
Georgeb
Wisconsin
George
K10 Burb Z71
I use one of these with a hose attached.
firebane
Calgary, AB
Curtis
That is what I use as well. I've had to get some smaller diameter tube and a zip tie to hold it on but it works well.
CSFJ
I've used similar ones before, and the pump mechanism always seems to quit working after a short time.
Georgeb
Wisconsin
George
K10 Burb Z71
It needs to be rated for petroleum based fluids. Mine has been in use for about 15 years.
CSFJ
The last one we had was supposedly designed for gear lube, but I'm sure it was the typical parts store quality. When I was at the dealer, we had a flush machine for diffs and transfer cases that ran off compressed air. The actual mechanism under the plastic bs wasn't very large at all. And, if you didn't use the snake oil they were trying to push, and purged the lines with the proper fluid for what you were working on, it worked pretty slick for refilling stuff. I may need to get in touch with a couple of old co-workers and see if I can track down where the parts to build one might be tracked down.
robert8096
Goose Creek SC
Robert
Try this one. http://motiveproducts.3dcartstores.com/1740-POWER-FILL-PRO-15-gallon_p_79.html
I have the power bleeder and just found a shraeder valve and a curved piece of steel tubing to make the fill part. I can use it to bleed brakes as well as fill things like the differential.
http://motiveproducts.3dcartstores.com/Universal-Bleeder-Kit-0250_p_136.html
The fill one can be pressurized by air but the bleeder one needs to be pumped up by hand.
I have seen people use a garden sprayer but they do not hold up to automotive fluids.
CSFJ
I have seen those. May end up getting the one you used. Wasn't sure if I could locate the parts to build a powered one for the same cost or cheaper.
Carb'ed Vortec 350
I cut a water bottle in a fashion that allows the "tip" to curl-up into the fill hole so the gear oil doesn't spill, and wide enough so when the rest is curled up I can squeeze small amounts, like 2 ounces a shot from the bottle, and then slow going. It works and it's cheap. :cheers:
CSFJ
I'm less worried about cheap, really kinda aiming for easy. If I can put something together for less than a $100 that works with the flip of a switch, I'll be happy.
ceyman72
