Flashing head lights
Tcoon6218
Michigan
Tyler
v10 Silverado
5.7 originally now 5.3l
When I am driving with my brights on all 4 headlights start flashing after a random amount of time. Unplug one bright on either side and it stops doesn’t flash with just the low beams.
1987 v10
squaredeal91
Cave junction Oregon
Greg bush
1991 SB
5.9 Cummins 12 valve
I'm guessing the circuit breaker is failing. Turning itself off, cooling and coming back on till it gets too hot again. Could be poor ground. I'm sure more knowledgeable ideas will chime in. @82sbshortbed went through this a short while back.
codfish
Drive a hybrid. I NEED your gas!!
Newfoundland
gary
I had the same issue, even after a new switch install.
Ended up buying a couple of relays and doing the relay upgrade. Lights noticeably brighter and no more flickering.
codfish
pistol85
