Fed up with light adjusters!!!
silverscottsk10
trafalgar indiana
mike
Bought new adjusters and they worked for about two minutes until I shut the hood, lights are crooked again, anyone have a different way to hold them?
What's the problem, are they breaking? Or just popping off the headlight bucket?
Do you still have the tension springs on your headlight buckets?
silverscottsk10
trafalgar indiana
mike
The plastic pieces keep snapping and 6$ for two adjusters is out of the question, I can't get them set close to right before they strip or snap the plastic
CSFJ
Are you sure the screws you're using are the correct ones for the application? sounds like they may be a bit too large.
silverscottsk10
trafalgar indiana
mike
They are the stock replacements
Same size as the original
But the plastic is cheap and strips or breaks on the first bump
I don't enjoy looking at the ground at night lol
CSFJ
That sucks. factory replacements or aftermarket?
So wait, are these new or used?
FWIW, the ONLY time I've ever had trouble with headlight adjusters breaking is because of a wreck or because they were old and brittle and I tried to remove them. And I've dealt with more than my fair share of headlight adjusters.
Dadof2
Central Texas
R1500 Chevy Sub, C20
350 in both trucks
I recently replace the adjusters on our 1991 Sub and the head lights have remained in place after 2-3 months. I bought them at O'rielly's if that helps or matters. Plastic appears to be quality stuff and we live on the worlds worst dirt road so they undergo a daily jarring and vibrations.
Ghetto
Hampton NH
Pete
4.1 6 Banger
I bought dirt cheap ones at my local parts store and they are holding up just fine..weird
VAL
TUCSON, ARIZONA
VAL
K10 SILVERADO
I had the same problem a couple years back. I just put a washer and nut on it. Its a pain in the ass to adjust them because you have to hold the nut with a small wrench while turning the adjustment screw. But once you have it where you want it, it stays there.
blublazn86
Bryan Texas
Shane
86 K5 BLAZER 84 GMC LWB 87 SWB Silverado
I got the factory ones for my 87 from my local Chevy dealer and I have had no issues at all with them. The GM part# is 365270. Hopefully that will help you.
silverscottsk10
trafalgar indiana
mike
So I'm not crazy lol, what I may do is a rectangle piece of metal wider than the hole, with two flanges to keep it from spinning and drill a hole and tack a nut to it, ought to hold better
mattyb
