Fan clutch resistance question
codfish
Drive a hybrid. I NEED your gas!!
Newfoundland
gary
How much resistance should a cold fan clutch have when spinning it by hand? I can move it. But it certainly won’t keep spinning when I stop moving it. It’s stiff but it moves.
I’m trying to figure out why it never gets above 130-140°.
Gonna get another thermostat today and throw it in. I’ll test it in water before I install it. New coolant sensor already installed. In the head.
Aluminum rad last year due to busted stock one.
Fan clutch next suspect.
Codfish
PrairieDrifter
North Dakota
Mason
350, 350, 350, 350, 350
It should spin like 1/4-1/2 revolution with a good flick maybe a little more.
75gmck25
Northern Virginia
Bruce
it’s full of fluid, which might have settled/gelled when it got completely cold. You might try starting up the truck, let it run for about 5 minutes, and then recheck the clutch to see if it loosens up a little.
Howeve, it sounds like it is probably working correctly.
codfish
Newfoundland
gary
Good point
I’ll try that
codfish
Newfoundland
gary
Still “stiffish” after 5 mins of running.
Well after going to town twice for a thermostat (wrong one in the first package-160 instead of 195), I have more questions. Maybe I’ll start a new thread.
After installing a new 195° thermostat and cleaning up the stock sending unit’s wire connection, I can watch the factory gauge creep up to 195-200, and watch it go back down when the thermostat opens. Great! I used my temp gun to confirm..
However, the temp readings on my Holley Sniper screen shows 150° or so. This was just idling in the driveway. Taking it on the highway in a few minutes so I’ll see what happens in driving conditions.
Why would there be such a difference in temps from the head to the thermostat housing? This is with a SMP sensor, as I assumed the supplied Holley sending unit was out of whack like others have suggested.
I was told the head is a better spot for the sensor. Might have to put the sniper sensor on the thermostat housing so I can get the required temperature for the sniper system to “learn”.
Thoughts?
Codfish
nvrenuf
Mobile, Al.
Seems like I remember reading about issues with the Sniper temp sender. Maybe check the EFI sub forum on CK5.com
codfish
Newfoundland
gary
Yeah I’ve already ditched the Holley temp sender for an aftermarket sender.
Twistedwhisky
