fair price? any thing i should worry about
Skweegle89
Oklahoma
whoops thats 73-76 but 77-87 is the same price.
MadOgre
NA
NA
NA
NA
NA
yep good looking out! thanks bud, and its that price always so I don't have to buy today.
You definitely need the raised Steering Arm! The Rough Country will ride nicer too and it comes with the arm.
73-76 is the same as 76-87 as long as the springs come with the poly bushings your all set to go. FYI change the front frame shackle bushings while your at it. http://www.energysuspensionparts.com/7801 Use the part # to order from anyone you choose. I would get some rubber boots for the shocks though! Once the cylinder gets nicked their toast.
And make sure that the U bolts in the kit are correct for the axle that you are using. I think there is a 1/2" difference in axle tube width between 1/2 ton and 3/4 ton axles. You definitely want the correct sized U bolts!
Also these are pretty useful and work really well! http://zoneoffroad.com/zone-offroad...-chevy-gmc-blazer-jimmy-pickup-suburban/c5401
use these with:
http://www.energysuspensionparts.com/3.5118
jmbcary44
NC
Jon
v1500 Suburban
5.7L 350 SBC
use these with:
wow, thanks a bunch useful info
nwapache
