factory gauges to autometer
coreys87
newyork
corey
v1500
looking to swap out my factory gauges to autometer or something. and swap the fuel to the rpm and get a small fuel gauge to put in the little cluster. can i swap out just the gauges and not have to re-run wires?
oneluckypops
Sedalia, Mo.
Luke
K30 SRW
The short answer, no way in hell lol.
actually if he could find gauges that would plug into the cluster it is possable, BUT the new gauges would have to have all the terminals in the same place as the factory, Only thing he might have to do is re pin his connector for the tach and the fuel gauge.
BUT I would agree I would rather just build my own little gauges harness that would plug into the vehichle connector. That way you just have to unplug 1 connector if you ever need to remove the panel.
rainyraven
wilhoit az
Ben
k10 cheyenne
ok.. my truck had auto meter gauges * or something like them* in it when I got it.. to do that thou you have to ditch the circuit board, and hard wire the gauges, also need to cut a little opening in the back of the dash gauge panel for each gauge to fit into the stock holes.. honestly its a real pain in the Butt and not worth the trouble..
since you truck wiring is all intact and still has the plug why not get these gauges instead there basically plug in play http://www.facebook.com/l.php?u=http%3A%2F%2Fstore.73-87chevytrucks.com%2Fmerchant2%2Fmerchant.mvc%3FScreen%3DPROD%26Store_Code%3D7%26Product_Code%3DVHX-73C-PU%26Category_Code%3D7G&h=HAQFIWQGHAQGcuDgCJhwNLZpLYrXUQkxS8qsSUWDDU0_HKA
smurph20
Clyde, Arkansas 72717
Brad
350/SM465/NP208/4.10's
Who wants to spend 800 bucks on just gauges unless you got a 10,000 motor in it.
I wouldn't spend $800 on guages if I had a $15,000 motor. I'd say the answer to the OP's question is, NO. Sure you can modify your bezel to accept the AutoMeter aftermarket guages, but you'd have to do away with the circuit board and wire your own guages. Of course if you know which wires do what, you can likley use the OEM wires from the circuit board plug, but you'd be curring the plug off. JMO . And it can be done for alot less than $800.
85 SWB I had all Auto Meter gauges
82 LWB that is my DD iEquss gauges
Both had to be rewired, it's not that hard.
heavyleft
Fayetteville, NC
V10/K5
350ci
Slowly working on exchanging all mine to Auto Meter. I plan on rewiring for the new guages. That way, I KNOW how/where they are wired for accuracy and troubleshooting.
EXACTLY how I'd handle it too. :waytogo: And a whole lot less than $800 or even $500.
I like full sweep guages. In these 2, I like the Auto Meters much better, but, I know there is also a big difference in price too. I"d probably have to settle for the Equiss too.
Irishman999
Safford Arizona
Jason
K-1500 High Sierra
One thing I noticed about the Equis gauges I have is their faces match the OEM speedo and Fuel gauge. I got my set from Orielys for about 30 bucks and found they fit in the stock holes really nicely, I might end up mounting them in the cluster after seeing all of this.
smurph20
Brad
I just got done taking my whole cluster apart cleaning and testing all the gauges to find out why the previous owner said they didnt work was becouse they had unhooked the damn things on the motor and didnt knwo what they were doing. So now i have to chase all the wires and reconnect them and get new sending units to make the oil pressure and temp to work.
82chevy350
Van Buren, AR
Joey
C10, K10, K5
There easy to mount in the cluster i just cut lines on the back side of the gauge holes and pushed the gauges through
Mike D
Huntington, WV
Michael
It is my opinion that VDO makes the highest quality guages. I have had to replace Cyberdyne and Autometer guages over time, however I have never replaced a VDO guage. The cost for the guages are very similar. The hassle is replacing it after a couple years. F.Y.I.
Mike D
Huntington, WV
Michael
To: HOTRODPC WOW!!!! What a neat looking panel. It looks way better than a factory job!
sleepn
