MannyDantyla
- Jan 13, 2015
- Lawrence, KS
- Danny
- K10
- sbc350/sm365/np205
I was hoping to avoid a dumb thread like this, but I'm totally stuck....
I washed the old engine bay yesterday to get as much grim and dirt out as possible. I used engine degreaser and a brush, then washed it away with a hose. The air cleaner was on and keeping water out of the carb and tried to not get it too wet, but I didn't worry much about it because I'm replacing the air filter.
I started the truck and it started just fine. Then the RPMs slowly went down until it stalled. I couldn't get it to start again. Now I run the starter and it cranks but it's not even trying to start at all, not even a stumble. Exactly as if I ran out of gas. So I flipped to the other gas tank, but it still wouldn't start.
Here's what I checked, in order
Help!
- First thing I did was check for spark. Of the two spark plugs I checked, both are providing spark. So I don't think ignition was the problem. Also, the plugs were completely dry.
- Next, I sprayed a little starting fluid into the carb. Engine did not start, sounded exactly the same.
- I thought maybe the distributor cap got wet and the firing sequence is now off. I opened it up and it looked bone dry. I sprayed some WD40 in there just be safe. Afterwards, engine would still not start. Starting fluid did not help.
- The guy at O'Reilly's said that a little water could have gotten into the carb and that it doesn't take much. And what I need to do is hold the throttle all the way open and crank the engine for at least 10 seconds. So I tried that, it didn't work. Now my battery is nearly dead.
Help!
