Engine Test Stand
Paladin
"Teufelshunde"
Wichita Falls, Texas
C30 Silverado Crew Cab Dually
@oldretiredafguy Attached are some photos of the engine test stand which I built over a decade ago specifically for my Big Block build. Am currently preparing to build another test stand for Small Blocks. Am posting these up so Mike can see them since it's not possible to add photos in a PM. If anybody has any suggestions, ideas, or comments whether good or bad I would like to hear them. Let er rip......:rockit:
P. S. The test stand I am preparing to build is meant to be passed down to future generations of Gearheads, aka kids, grandkids, great grandkids so will be built to meet outstanding safety specifications!!!
Bennyt
Surprise
Ben
Nice, looks very stout!
If I ever bought one, I'd like to see a heavy shield to catch a grenading balancer or flexplate/ flywheel. I've seen quite a few come apart working around dynos when I was younger.
Paladin
"Teufelshunde"
Excellent thoughts, here is how I covered the flexplate. :smoke2:
Bennyt
Surprise
Ben
You really did a good job on it!!!
Is that an actual SFI scattershield or a bell housing? Seen a lot of bellhousings blow apart, especially the aluminum ones.
I'm not trying to be a PITA, just seen more than a few mishaps on dynos and at the strip. Friend of mine got his legs torn up on an old front engine dragster by a flywheel ringgear, similar to when Don Garlits almost lost his legs.
I've seen probably 5-10 balancers come apart, 1-2 converters, 1-2 flywheels, 1-2 flexplates, lots(probably close to a 50 plus) of cheap chrome pulleys, alternator fans, lots of fan belts. Usually goes right through hood, floorpans, fenders, etc whatever is in its path.
Call me superstitious or what not, I don't like being around dyno's or test stands when under load, or standing in front of cars when rev'd. A lot of shops don't always strap cars down when chassis dyno on mild cars but I do it every time.
78C10BigTen
pennsylvannia
C10 BIG TEN
Stand and BB are beautiful!
PrairieDrifter
North Dakota
Mason
350, 350, 350, 350, 350
I personably wouldn't want the gauges mounted on the radiator!
On the one we had, we made a small little instrument panel, ignition switch with a push button for the starter, water temp, oil pressure, is pretty much all you need. But it was all prewired and hardlined, so you just drop the motor in and hook it up and go.
Build a battery tray! If you plan on using batteries to start em that is, we put ours on the passenger side pretty much under the rad. Just need a few pieces of angle iron.
Edit: maybe a spot for a small fuel cell as well, I always wished we had done that on the one at the shop, I'd like get mine built as well.
wanderinthru
Mid Point Route 66
Shakey
81, 70, 75, 84, 89
K 10, C 30, K 20
Needs a fan on the radiator..... Grin. Damn nice work!! Ill be checking it out closer, prob asking you questions in the hopefully near future when I build mine. Again, very nice work!!
Carb'ed Vortec 350
@Bennyt
I guess I have been lucky. Do flywheels typically grenade? Same for flex plates, and dampeners? I was going to break in my 292 on a stand, but if things will fly apart, I will break it in installed in the truck.
Nasty-LSX
TogetherforeverCovid19
HOUSTON TX
Mi Hung Lo
c10/k10/k20
LSX
Cool man. Looks heavy duty!
nathanjohnson85
