Engine / exhaust noise care to take a stab at what it might be?
SirRobyn0
Rob
Truck 1984 Chevrolet C20 305. It's always had somewhat of a minor putting noise, but recently it has become more obvious. I generally cannot feel it, or barely feel it in drive, but in park there is some pretty obvious rhythm. Going down the road the truck runs great with no odd noises or sensations. I checked the vacuum at idle, the gauge needle read 20 and stayed nice and steady. I checked the base ignition timing and made no adjustment. It never does this when the engine is cold, even after it's come off fast idle. Gotta drive it 20 minutes or so before this shows up.
I'm thinking it's a weak exhaust valve or spring. What do you think?
squaredeal91
Cave junction Oregon
Greg bush
1991 SB
5.9 Cummins 12 valve
I've heard other engines sound like this. Probably something w/ valves. Odd question. But Will it try to suck up a dollar bill at the tailpipe?
SirRobyn0
Rob
Not an odd question to me, I test I've run and shown others that trick. I have not tried it on the truck but should.
fast 99
Spokane, Washington
Valve guide wear? Baffle in muffler? Have seen that a few times. Doesn't always show on vacuum gauge.
SirRobyn0
Rob
I'm right there with you on the vacuum gauge thing. I don't think the sensation that is there would be present if it was baffle in the muffler.
Basically you and @squaredeal91 backed up my thinking, but you never know sometimes someone will see or hear something different. I will do the tailpipe test with a shop rag the next time it does this. The entire drive into work today and it did not act up, so we will see and I will report back.
Thanks.
Garcjay
