Electrical problems with headlights and blinkers
Codypicz24
newberg oregon
Cody
c20 1985
Hey everyone I hope your having a good day so my issue is that the cornering lights go on with the blinker and I have one solid light I will provide pictures what would be the way I could fix this. I’m not a mechanic so all this is new
Codypicz24
newberg oregon
Cody
c20 1985
P.S the right front blinker, works fine but for some reason isn't one same for the cornering
Scott91370
Burleson, Tx
Scott
Sierra1500
I'm a little confused here.
There are 3 blinkers on your truck for each side.
1 - front bumper
1 - front fender/corner
1 - rear taillight housing
If any one of these do not light up and that side doesn't blink you probably have a burned out bulb.
When you turn on the RIGHT blinker what happens?
When you turn on the LEFT blinker what happens?
Codypicz24
newberg oregon
Cody
c20 1985
1 - front bumper
Sorry I should have explained better so, when I turn on the low beams if you can see in the pic only one of those lights are on are both of them susposed to be on? And the same side that light is on the Cornering light is on to. But the other side is completely out. Unless I use the blinker in which it works.
Scott91370
Burleson, Tx
Scott
Sierra1500
When you turn on your headlight switch to either first (parking lights) or second (parking with headlights) position, the lights below your headlights and the corner light should all come on.
Check grounds. Probably not the issue here since the blinker and parking light share ground.
You will need to check with a test lamp or volt meter starting at the socket working backwards towards the bulkhead on the firewall to see if there is a break in the wire.
Codypicz24
newberg oregon
Cody
c20 1985
will do!, thanks i will be sure to check that out
Codypicz24
newberg oregon
Cody
c20 1985
So wires seem to be fine, but I noticed that this cornering light is VERY DIM,should I take off the plastic sheathing off the wires to see if there is maybe a broken wire?, or do you think it’s fine
Scott91370
Burleson, Tx
Scott
Sierra1500
I would measure voltage before cutting wire. Then work backwards towards the bulkhead to see if there is a crack/break.
Codypicz24
newberg oregon
Cody
c20 1985
Hey everyone just a update, so while testing everything I took out the passenger side blinker bulb, and the driver side one came on without any problems so it seems to work when there isn’t a bulb in the socket any ideas?
sidschev
Arkansas
sidney
c1500
sounds like a grounding problem. check grounds (ie remove them grounds and reinstall them grounds )='s new contact for grounds. maybe sand them a bit as well....
Codypicz24
newberg oregon
Cody
c20 1985
I’ll try to snap a pic because the headlight grounds near the hood, and I’m not sure where the blinker is susposed to ground
Test voltage across the socket, does it closely match battery voltage? If not check power side of socket to battery ground does that match battery voltage? Check negative side of socket to battery +, does that match battery voltage?Now put the bulb back in, back probe the ground at the socket in dc volts mode on a multimeter. Check ground side of socket to - battery post and positive side of bulb socket to battery + readings should be nearly 0 volts .5 volt or more you found your problem side. Depending on how many connection points there are on the wire.5 maybe a little on the high side, but close enough.
Codypicz24
newberg oregon
Cody
c20 1985
Just an update I replaced the socket and everything works fine now!!
sidschev
Arkansas
sidney
c1500
so a short in the socket was the culprit ......glad you got it fingered out...:D:birgits_tiredcoffee
Pugs Speed Shop
