Electrical issues
adriner
Out in the sticks, PA
Adam
k25, c20
350 nv3500, 6.2TD th400
Well after looking at the wiring schematic I found my problem. The ground wire was completely severed from the drivers side and the pass ground wire was just holding on by a few strands. Replaced them and now it's good as new. I shoulda just looked for a bad ground to start with, that always seems have something to do with the electrical problems I run into.. Thanks for all your help fellas!
MrMarty51
Eastern Montana
Martin
So it's just the front driver's side lights then technically is what you are saying? After the front body connector there is a splice that splits the brown wires to run to all the front park lights but I think you have a grounding issue or bad bulb or socket. Usually if the signal indicator in the dash is lit up it's back feeding current. I think you have a bad signal bulb. Check the turn signals operation as well and report back.
Mine does this exact same thing and I found the ground wire is ripped out of the back of the turn signal socket. So I have to replace that now.
Its usually just a bulb though, like 89s said.
Sent from my iPhone 4s using Tapatalk
Holy ****. :wtf: Sounds like a grounding issue somewhere. Let me dig up some tests...
Did you take the ground straps off the core support and clean them up? A lot of times they'll get a little crusty and not get a good ground. I had a dim DS headlight because of that.
:bleh::happy175:
Stroked
Beloit, Kansas
Jared
Glad you got it figured out. Sometimes electrical problems can be a real bugger.
adriner
Adam
k25, c20
I absolutely HATE doing anything electrical. It literally gives me a headache trying to figure it out. That's half the reason I stick with the old squares is cuz they're so easy to work on
MrMarty51
Eastern Montana
Martin
There was a time that I was like that.
Then----- shortly after I started wrenching for the Montana DOT there was an old wore out Alice Chalmers Loader that the engine was getting tired in,it also had multiple electrical problems,Always something or other shorting out,I was assigned that project.
Out came the engine,then the center pivots and electrical harness,completely stripped out,tagged each and every connector then stretched that harness out on several old plywood signs,nailing down each comnnector and splaying that harness out,cut off the electrical tape,banding a piece of tape around the harness at the intersections then duplicating that harness,less the connectors,got it complete then cut the pigtaqils off the old harness and soldered them onto the new harness,except for the ones that were availeable.
Completely rebuilt that old Alice,front to back,top to bottom,and all the hydraulics in between.
I got that old critter back together and every electrical item in it worked perfectly,the first time.
That ended My fear of electricals,what a good lesson.I learned to always start with the grounds,unless it was something real obvious.
Throughout My 31 years with them there were a lot of wiring issues but I never had another project like that one again,although,I was restoring a 1957 Triumph Thunderbird motorcycle and rebuilt the harness for that,it was easy compared to that old Alice.
Good job Adam! :High 5:
Marty I always like your old stories man. :)
dob555
