Electric issues
Joshua Bailey
Colorado Springs
Josh
350 small block
So I have a 85 Chevy 4x4 C10. I just recently replaced the headlights and realized I have a fluctuation in them. The battery and alternator check out. What else could it be?
Charlie
Euless, Texas
Don
Cheyenne 10 LWB
350/TH350/AC/4 BBL Quadrajet
:welcome:
Frankenchevy
Proverbs 16:18
Square
CUCV
Small
Any aftermarket accessories, radio or does it correlate with using your wipers or anything similar?
Joshua Bailey
Colorado Springs
Josh
350 small block
No radio, wipers are effected as well as windows going up and dow .
Dmack
Central OR
Dave
Are you just seeing the flux at idle? If so,not uncommon as the regulator doesn't always let the alternator kick in until a bit above idle.
Frankenchevy
Proverbs 16:18
Square
CUCV
Small
Check voltage at alternator post, at battery and at firewall junction—all while idling. Any variance?
Joshua Bailey
Colorado Springs
Josh
350 small block
Have not checked that. If there is a variance what should the next step be. Side note I am completely self tought on mechanic stuff and absolutely no knowledge electric wise.
Frankenchevy
Proverbs 16:18
Square
CUCV
Small
I’d check for loose or brittle looking wires between the alt/batt/firewall junction/bulkhead fitting. If you find nothing obvious, try probing on either side of fusable links. Clean the bulkhead connectors really well.
Whenever multiple items are impacted, I’d tend to suspect something upstream.
Frankenchevy
Proverbs 16:18
Square
CUCV
Small
Firewall junction in yellow, bulkhead connector in green, alt post near red arrow. Try to use a common ground for the tests.
Joshua Bailey
Colorado Springs
Josh
350 small block
So tested all those location and no fluctuations. The electric does not fluctuate in park, a little at idle in drive an a little at low speeds. Checked all wires and connectors nothing is loose.
dvdswan
Port Orchard, WA
Dave
Did you just check to see if they were tight or did you check for corrosion by taking them off and inspecting them?
Mark Desaulniers
Canada , British Columbia, Coombs
Mark
GMC Camper Special
350 CID
I copied this from my other post today;
I am a master electrician. I have worked in a custom Electric Vehicle shop doing R&D and have a mini farm with plenty of equipment to give me problems. Some may think it's excessive that i clean and apply electrical grease to battery connections and grounds on an annual schedule. The weather in my region is zone 7 and salty fog being coastal with mild winters. Everything is wet from September to May. Anything unprotected corrodes. My shop friends are the following spray cans on a shelf like little soldiers ready for war. LPS, Fluid Film, T9 boeshield, Silicone spray, white lithium, oxide electrical grease ect. All my equipment has high current flexible ground straps bonded to the starter cases, the chassis, and the back of the alternators back to the battery negative. This makes sure the engine critical components are at a negative potential and not being used as a path for current to flow. For this I get starters that engage, alternators that charge and no electrolysis destroying the engine metals. I look at it all like Its a marine environment.
Poorly grounded alternators or poor connections to the alternator can cause the internal voltage regulator to be unstable. Looks like some kids playing with a dimmer switch on your headlights causing them to go from dim to bright kind of oscillation. That said I have found that when all connections to the alternator are %100 some still do it. I took those alternators out to closer examine on my bench. This is what I discovered. The pot metal case the alternator is housed in was corroded and not providing a good connection to the internal regulator electronics that are bonded to ground via the alternator pot metal housing. So a bad connection internally cause the regulator to be constantly adjusting the field current. Solution was to glass bead or clean and lube the inside of the alternator housing and reassemble. My shop records show two instances of a pooched regulator as well. The 10si and 12si regulators usually work or not. Not much in between. Other alternators can have a bad (hunting) regulator that still charges even know the voltage is like a yo-yo
MikeD
