Electric fuel pump on dual tanks?
82flatdeck
calgary
rylan
k3500
did you use a fuel pressure gauge on your system?
and to everyone else thanks for the ideas and info
Yes you will need a fuel pressure reg or u will overflow your carb.
Ryder73
Alberta
Adam
383 Stroker
ok thanks
87scotty
Central il
Andrew
V20
5.7 for now
A regulator with a return is what I'm going to be running think its easier on the pumps
Ryder73
Alberta
Adam
383 Stroker
Guess my next question is. whats the advantages and disadvantages between a mechanical and electrical pump. i found a mechanical pump that pumps 110 gph which is the same as the electrical one i was looking at. with the mechanical pump it would work out to way cheaper.
Im so confused
adam
82flatdeck
calgary
rylan
k3500
Im so confused
adam
As per the name pumps will pump better than they suck. the further back you can put the pump the better. Also when a pump sucks it can create vacuum causing vapor lock. the harder the pump is sucking the greater the chance of vapor lock.
K5Chris
