Electric Fans
You guys with electric fans have you had to upgrade your alt to make up the lost power
It's not totally necessary, but a strong battery helps, and alt upgrade is not a bad idea at all. Also a big 3 upgrade is alwayss a goood idea.
NOPHO84K30
north phoenix
justin
1984 silverado k30
K30 dana 60 corp14 ff
454 sm465 np205
I have two red tops with a isolator. One runs truck ... one the stereo. . winch.. lights Theres a shop that will rewind my alt for $1 amp the biggest itl go is 140 amp then the case is in the way. Its not bad idea cant hurt. Already did big three
austinado16
Central Coast, CA
1990 w/307k miles on the clock
GMC V1500 Suburban SLE
5.7L TBI/4L60/3.42's
Great thread! Liking the big dual fan setup. Wish someone would tow in the mountains and heat so I can see how it'll work under those load conditions.
A couple years ago I found the aux 454 fan at the swapmeet for $2. Installed it in front of the 11x11x1.5" TruCool (aka; B&M Super Cooler) trans cooler. The motor got water in it and failed about a year later, but I discovered the company that made the fans is still in Australia, so I ordered a new fan motor. I've since added a stainless band to act as a shroud and improve air flow.
Snips71
